-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   07 Outback Hood Latch Opens Partially (http://www.diychatroom.com/f46/07-outback-hood-latch-opens-partially-122390/)
Jazan 11-04-2011 06:22 PM
My 2007 Subaru Outback's hood has started popping up now and then
as I drive down the road. The hood does not open. It just goes to the
first release and shakes until I stop and re-close it. It's been happening
more and more as time goes on.
I have lubricated the mechanism and the linkage, but this did not help.
Has anyone here experienced this before? What should I look at now
as the possible cause? Or does this require a technician?
cjm94 11-04-2011 08:29 PM
Make sure the release cable is returning all the way. If it is the latch is most likely shot. If not releasing you need a new cable they get old and bind inside the outer sheathing.
Mack daddy 11-05-2011 12:34 AM
As a master Subaru tech of 20 years, try to adjust the latch first!! It's not up high enough.. It's only 3 12 mm bolts and slide it up.. Is the car from the east coast??
Rust can cause this latch problem also.. Has the car been wrecked?
Jazan 11-05-2011 06:31 PM
Follow-Up On Subaru Hoodlatch Problem
Thanks you both for your helpful replies. The cable is in good shape and moves freely. No rust or dirt in or around the latch mechanism. When I
decided to try the adjustment by loosening the three screws, the upper
two are reachable, but the lower one is blocked. Is there a special tool for that one? Or is does the grille have to come off before I can loosen it?
Also, once I get the screws loose, are the screw holes slightly slotted
to allow for adjustment upward as you suggest? Thanks again!
Mack daddy 11-05-2011 07:24 PM
You can get a swivel socket on it.. It does. It have to be loosened much.. That should take care of your problem...
