11-06-2008, 06:51 AM
#1
03 silverado speedometer
I have a 2003 silverado and the speedometer just started acting up. the MPH needle will reed much higher than the actual speed. right now it sitting on 60 when stopped. the odometer still records the correct miles. where do I start?
11-06-2008, 09:05 AM
#2
I am assuming your truck is not heavy duty, as it may be different than a passenger car or 1/2 ton truck. Most newer vehicles get their speed input from a VSS sensor in the transmission, routed through the transmission controller, the BCM, then to the IP cluster.
Your controllers and IP cluster communicate on a class II data line. I do not think there is a problem with these wires as you would generally have multiple problems.
My guess, bad speedometer, because you say the odometer is fine and the BCM is probably sending a correct mileage signal to the cluster, but it still could be a BCM. The mileage of your truck is stored in the BCM, not the cluster.
I would start by taking the truck to a qualified repair shop equiped with a tech II or equivalent. With a tech II, they can scan for diagnostic codes or flags, check for proper inputs at the TCM and BCM and command the BCM to control the speedometer.
Don't guess, test and good luck.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
11-06-2008, 07:54 PM
#3
thankyou
01-31-2009, 03:27 PM
#4
Before you get too involed, I would talk to your local dealer G.M. has a special policy repair on truck speedos. I don't remember all the details, but I think it covered '03 to '06 models up to 70,000 miles. Even if your truck has more miles, you might get some help. This special policy covers
the cluster unit only, but from my experience about 99% of failures are in
the cluster.
02-09-2009, 12:43 AM
#5
A lot of the 03-05 silverado's actually have this problem. I had 2 friends that it happened to. They ended up having to buy a whole new cluster though because all of the mechanics told them there was nothing they could do. But, if you havent got it fixed yet, when it used to happen to my friend, he would turn his truck off and then turn the key back and forth to the "run" and then "off" position and the needle would slowly go back down to 0 mph. It would read right for a few days but then it would start acting up again.
02-09-2009, 12:54 AM
#6
I had an 04 Silverado that did this. Luckily mine was a failing speed sensor. Very easy to fix. Apparently, on this year range, there was a slight design flaw which would eventually cause voltage to build up and store in the sensor, kind of like a capacitor. I replaced the sensor with a new OEM unit from the dealership, and the problem never occurred again before I sold it in August of last year.
The mechanic at the Chevy dealership tried to convince me that I needed a new cluster, first. The price difference was almost $200, so i opted to replace the $87 speed sensor first. I would check voltage on the sensor, before you replace the cluster. Sorry, but I can't remember the optimal range at the moment.
02-10-2009, 10:38 AM
#7
There is a Service Bulletin on this issue, and dealers are well aware of it. It recently happened to my 2005 GMC Sierra. The bulletin technically covers only 2003 and 2004 model years, but I got mine fixed for just the labor cost ($60). The part is nearly $300.
02-10-2009, 07:28 PM
#8
As stated earlier this is 99% in the instrument cluster,
you should definitly check with your dealer because this may be able to be fixed for free because of the special policy because of so many failures of the speedo head.
You can not just put in a new cluster yourself because it needs to be programmed to the vehicle.
07-23-2009, 11:59 AM
#9
I also had a speedometer problem in my 2004 Chevrolet Silverado
the speedometer was not working at all and I found a website where I had it fixed for $140. That was a lot cheaper than the $700 that the dealer wanted to replace the instrument panel.
Here is the website
in case you want to check it out: http://www.speedometergaugerepair.com
01-27-2011, 05:04 PM
#10
Logged into this forum to let you guys know that GM, specifically my Chevy dealership here in Cleveland Ohio is honoring the special extension of the warranty for the instrument cluster stepper motor issue...
Just started happening to my truck last week and now the speedo is pegged out and doesn't move.
On one of the forums, there is talk about the extra warranty and it is true. I will have to take the truck in for them to verify the trouble and get the correct part number, then return for them to put the new instrument cluster in. All for free, parts and labor are completely covered.
On a web site I found it talked about a mileage limitation, all work free till 70,000 miles and truck must have a vin inside a particular range. Apparently mine fits. Also, the site mentioned a limitation of 7 years from date of service. I have a 2004 Silverado 2500 HD and they are doing it for free next week when the cluster comes in.
All of the info here and other forums has been such a big help I though I would share...
01-20-2012, 12:32 PM
#11
this whole cluster experience has been a nightmare, not so much about the cluster but the whole business of getting it taken care of. Went to the dealer about a recall on our 2005 Silverado and told them also about the problem we have been having with the speedometer. They called back to say it was the cluster and would be $450. to have it fix. Told them that we would have it done at another time. I went on line to read about the cluster and that's when I found out about the lawsuite. I called GM spoke with the representative told her the mileage was 79000, she ssaid that it would be covered parts and labor. Asked 3 times, placed me on hold and said yes. She went as far as calling the dealership and telling them that parts and labor would be no cost. Called me back and said she called them and to go ahead and make the appointment. Did that double checked with them and was told no charge and made our appointment for 7 days later. While the truck was in the shop taken apart and 6 and 1/2 hours later GM called to say oops you have to pay for labor if we choice to have it repaired. To make a long story short here it is 3 days later truck is still in the shop not done. Good luck to everyone GM will not to our next
vehicle. Neither GM or it's dealership seems to know how to take care of their customers.
01-24-2012, 10:32 AM
#12
vehicle is a 2003 silverado 4x4 Z71, 5.3L V8, approx 103k miles.
I had the famous problem of a sticking speedometer needle in the gauge cluster when it got cold outside. This weekend, I replaced all 6 stepper motors in the gauge cluster. It was a pain in the ass, but I got it done.
My gauges seem to be working okay now, but the response of my speedometer needle seems to be delayed. For example, when I slow down, it seems like it takes longer than it should to return to zero. For instance, if I drive 20-mph, then stop at a stop sign, it will still be traveling back to zero for a few seconds after I stop.
This leads me to believe it wasn't the stepper/stepping motors in the cluster - and maybe it's something else. Is it possible that the speed sensor that has started to malfunction?
I always wondered why my speedometer would always stick when it got cold (and no other gauges).
Any advice? How many speed sensors are there, where are they, and how can I replace them?
Thanks for the help!
10-28-2012, 08:40 PM
#13
We had the same problem in our 2004 Chevy Silverado. It started with the speedometer,then the oil and the tachometer gauges. The PRNDL display also went dim where it would only light up part of the time. After some research it turns out these GM instrument clusters have up to five issues with them. The stepper motors go bad in the gauges,the back lighting goes dim or dead,the PRNDL goes dim or dead and the whole cluster will just lose power. We called GM Gauge Repair or http://www.gmgaugerepair.com/ and they did a complete instrument cluster rebuild for 125.00, had it done the same day and they shipped it back with FedEx Ground. Great service and very friendly people to deal with. We did not need to program the odometer or VIN because they rebuilt our original instrument cluster!
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
