Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Safety
Old 10-12-2009, 09:10 PM   #1
What should I do about this non-working motion sensor light?
I recently set up a motion sensor light as security for the back of our building. Unfortunately someone took it into their head to adjust it, and disabled it.
I've been trying to make the light work again, but it appears to be damaged. The range on the sensor is down to nothing and I can't seem to adjust it.
Is there a way to fix this? Or should I just replace it? The motion sensor light I installed was a heath zenith SL 5411 A.
darsunt is offline   Reply With Quote
Old 10-12-2009, 09:53 PM   #2
Residential Contractor
Those motion sensor lights are sometimes easy to install, but a little tricky to operate.
There may be several "modes" that it can operate in. Check the instruction manual.
Some of these change modes by flipping the light switch off and on one or two times. If it is hardwired, try turning the circuit breaker off and on a couple times.
rselectric1 is offline   Reply With Quote
Old 10-13-2009, 12:39 AM   #3
I found the problem. I was using regular bulbs, and the unfocused light was confusing the light sensor, it wasn't sure if it was daylight or nighttime. I think it kept going into day mode (auto) and the lights would not go on when the motion sensor detected something.
The halogens have focused light, they shield the light sensor so it knows it is night time. I did not know about this!
Anyways the motion sensor light is working, and the back of the building is more secure.
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 09:35 PM
Motion switch wired to two circuits Sibkuz Electrical 2 04-22-2009 08:31 PM
Motion flood "non-standard" wiring Fishin_Man Electrical 5 01-14-2009 04:20 PM
Halogen motion sensor light stopped working, Incandescent still works keyser soze Electrical 6 05-29-2007 09:53 PM
