Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Safety
Old 12-17-2007, 10:29 AM   #1
Water pH Levels
I am currently installing a hot tub in my house, and I have been hearing different people talk about testing the pH levels of the water before actually connecting it to the tub.
Does anyone have any knowledge on this, its something I am a bit stumped on. Thanks
rsmith1024 is offline   Reply With Quote
Old 12-17-2007, 09:58 PM   #2
Eibwen
Water pH Levels
No need to test the water PH before you fill the hot tub.. But once you fill it and the hot tub is in operation its very important to test and maintain water PH on a regular basis just like in a pool.
Proper PH allows your sanitizer to work at the optimum level. With hot tub water being heated its very important.
Check with your installer or a local pool company that does hot tubs for a test kit and instructions.
Sammy is offline   Reply With Quote
Old 12-18-2007, 04:41 PM   #3
Water pH Levels
Thanks for the feedback! I was talking to a buddy of mine and he mentioned the same thing. He also said that I can get the pH stuff online.....I think the site was XXXXXX ......heard of it?
Last edited by AtlanticWBConst.; 01-22-2008 at 05:58 PM. Reason: Advertising Link Removed
Old 12-18-2007, 08:53 PM   #4
Eibwen
Water pH Levels
I've never seen the site before but the test kit you need should only be about 15-20 bucks and available local at a pool/spa store.
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
