Water Damage In Basement - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Old 07-07-2014, 10:48 AM   #1
Rewards Points: 53
Water Damage in Basement
Just finished drain tile installation in our basement after multiple instances of water intrusion.
We are planning on remodeling the basement in about a year. We have cut back 4" of the existing paneling around the bottom, and some locations have drywall behind that also has been damaged. The drywall has likely wicked up much higher on the wall, and we are looking for temporary relief until the remodel.
Per attached pic's, if this is bleached and covered for a year with temporary baseboard, do you see any serious causes for concern?
smrf1080 is offline   Reply With Quote
Old 07-07-2014, 12:01 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,984
Not really.
If you got the source, treat with bleach and it should kill/make inactive the spores.
crawlspace slab voids, basement water geoffmiller Building & Construction 0 11-25-2011 09:01 AM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
Need some advice on buying home termite & water damage. Mr Heshup General DIY Discussions 1 03-29-2009 03:06 PM
