Vacuum Cleaner Plug Scorch Marks - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Old 07-15-2012, 09:16 PM   #1
Rewards Points: 12
Vacuum cleaner plug scorch marks
My 1 year, 3 month old Dyson vacuum cleaner works fine but has some burn or scorch marks on the prongs of the plug. Replace or repair? My house is 30 years old and I am in the process of replacing all of the outlets.
dfiddler is offline   Reply With Quote
Old 07-16-2012, 01:36 PM   #2
You are using a worn out socket so that the plug is easy to pull out and there is excessive contact resistance between the plug and socket and so you getting excessive localized heating, which further increases the contact resistance by removing the temper of the spring contacts in the socket.
Or not!
The Following User Says Thank You to Yoyizit For This Useful Post:
dfiddler (07-17-2012)
Old 07-16-2012, 11:13 PM   #3
If its black with carbon, a little emery cloth will do. If its pitted, replace the cord after you fix the receptacles! No sense burning up the new plug too.
Evstarr is offline   Reply With Quote
The Following User Says Thank You to Evstarr For This Useful Post:
Old 07-21-2012, 07:43 AM   #4
Rewards Points: 1,452
After cleaning the prongs, try plugging into a different receptacle and after just a few minutes of vacuuming, feel the plug. If the plug is hot then a bad connection has developed inside the plug and you need to cut it off and replace it.
The Following User Says Thank You to AllanJ For This Useful Post:
dfiddler (07-22-2012)
Old 07-12-2013, 03:50 PM   #5
This can be very dangerous I'd suggest to replace it. When you fix all your outlets
get a nice Hoover or Miele for your home. Read up here http://the-best-vacuum-cleaner.com/ for all the information about the vacuums.
ecmom is offline   Reply With Quote
Old 07-13-2013, 08:57 AM   #6
firehawkmph's Avatar
Rewards Points: 1,826
Just curious,
are you getting scorch marks that look like they are caused by the prong overheating, or are you getting marks from pulling the plug out while the vac is still running, causing an arc?
Pictures?
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 09-02-2013, 08:53 AM   #7
Rewards Points: 3,130
Originally Posted by ecmom View Post
When you fix all your outlets get a nice Hoover or Miele for your home.
Good advice. Every vacuum we'd ever owned in the past had been a Hoover, Eureka, Bissell, or the like, usually from some place like WalMart. Then my wife bouglt a Miele - wow, what a difference! Far and away the best vacuum we've ever owned. They are expense, however - almost $800 for the model we have, but worth every cent. And no, I don't sell vacuum cleaners.
removed old romex (added new wire) and added a plug doesn't work now? Limit54 Electrical 9 11-08-2009 10:03 PM
Out door plug Red Squirrel Electrical 11 09-06-2009 08:04 PM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 10:49 AM
20 amp plug MikeyP Electrical 6 01-03-2009 10:04 PM
New plug for toaster oven? mike720 Electrical 3 11-23-2008 08:44 PM
