Which Of These Respirators Should I Buy ? - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Old 07-31-2014, 10:09 AM   #1
Rewards Points: 129
Which of these respirators should I buy ?
http://www.amazon.com/GERSON-Signatu.../dp/B00CF4I2WM
http://www.amazon.com/3M-07192-Paint.../dp/B0002STR22
Which $17 one is better? Gerson or 3M ?
Or should I get this $27 one?
http://www.amazon.com/3M-Paint-Proje...dp/B00004Z4EB/
Mathlete is offline   Reply With Quote
Old 07-31-2014, 01:23 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
It depends on what you are protecting yourself from. Since you are looking at half-face units, look for one that has a NIOSH rating N95. Make sure that whatever you get has replacement cartridges available. Get P100 cartrideges for particulates (dust, lead, mold spores and fragments, etc.). Use organic vapor cartridges for things like paint fumes, chemicals, etc. Good units will allow you to stack cartridges. Personally, I prefer ones that have provisions for prefilter cartridges to be snapped over the primary filters. Prefilters are pennies compared to several dollars for the primary. When you finish using it, make certain to remove the filters and wash the mask in warm soapy water. Then rinse it well. You don't want nasty things growing in the moisture from your breath that has been left in the mask. Another important thing is to make sure you buy the proper size so that it seals correctly. Most people tend to buy masks that are too large.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
Windows on Wash (07-31-2014)
Old 07-31-2014, 04:07 PM   #3
Rewards Points: 129
I ordered the $27 one. Is it decent?
Old 07-31-2014, 06:05 PM   #4
It has an N95 NIOSH rating, so it's not a toy. But it doesn't really say what the filter cartridges are rated at, so I'm guessing they are P95s. That means they are 95% efficient. P100s are 99.97% which is equivalent to HEPA. That is about as good as it gets and which is why I recommend P100s. Even with P95s, it's still hundreds of times better than those cheesy "monkey" masks they sell at the box store.
Difference b/w these 2 respirators? Mathlete Painting 0 07-30-2014 11:14 AM
Are these good respirators and safety masks? darsunt Tools 3 02-24-2013 08:34 PM
Respirators for Spray foaming TurboDIYer Insulation 2 02-21-2012 12:15 PM
