Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Safety
Old 08-09-2011, 05:01 PM   #1
Learning by Doing
Leah Frances's Avatar
Test your smoke DETECTORS!
One of our smoke detectors started doing the "battery low" beep a couple nights ago. After trying to make sure the house wasn't burning down, I pulled the battery and went back to bed.
Since I had to do one; I decided to replace all the 9Vs in all my smoke detectors. I discovered that TWO of my Kiddie Model 0946 Ionization Smoke Alarm are DEAD. I shot some compressed air in it, per manufacturer instructions, and tried multiple new-out-of-the-package 9Vs. They are listed for 10 years and were made in 2006 (November 15, according to the sticker).
So, TEST YOUR DETECTORS.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-09-2011, 06:13 PM   #2
I change/check mine when the time changes.
josall is offline   Reply With Quote
Old 08-09-2011, 06:36 PM   #3
Learning by Doing
Yeah, me too. But they all tested fine on the last change to DST. Twice yearly tests, clearly are not sufficient.
A non-functional smoke detector you THINK is working = no smoke detector.
Old 03-05-2012, 10:09 AM   #4
Smoke detectors are connected to a fire alarm panel or a fire/burg panel. Smoke alarms are not connected to an alarm panel. Smoke alarms may or may not be interconnected. If the smoke alarms are interconnected, all smoke alarms are supposed to sound if one is tripped.
Smoke alarms have a 10 year life, at the end of the 10 year life cycle, they should be replaced. But, dust may plug the sensing chambers before the 10 year time period is reached. If the canned air does not clean the smoke alarm/detector,you might try a vacuum cleaner. But, at less than $30.00, replacement cost is not a big deal.
Most smoke alarms now use 10 year batteries. But, many of the batteries fail prior to the end of the 10 year time period.
Kidde now has a built-in battery. At the end of the 10 year life, the alarm starts to beep. Then you just replace the whole unit.
Reminds me, time to check my smoke alarms. Except my can of smoke is in the van, which is in the shop.
fireguy is offline   Reply With Quote
Old 06-20-2012, 10:10 AM   #5
If the smoke detectors are connected to the house wiring,(they all go off when one goes off) will they work with a dead battery?
Is the battery basically just a backup for a power outage? Just curious.
mikegp is offline   Reply With Quote
Old 06-20-2012, 12:14 PM   #6
Since my fire started in the garage- does anyone put a detector in their garage? I had no warning as I was watching tv as my garage was burning, I didnt even know till paint cans started exploding
pwgsx is offline   Reply With Quote
Old 06-21-2012, 11:40 AM   #7
Licensed electrician
The battery is for a power outage.
Old 06-21-2012, 11:41 AM   #8
A heat detector would be better in a garage. The exhaust from a car could set off a smoke alarm.
Old 06-21-2012, 12:11 PM   #9
good to know, ill look into that for sure.
Old 06-25-2012, 12:33 AM   #10
Wire Chewer
Red Squirrel's Avatar
I test mine with smoke once in a while. It's great and all the press the button but all that does is test that the beeper and the battery is good. Same way I like to est GFCIs with a light socket. If a product is designed to protect against something you want to dish out that something in order to test it.
I have one smoke detector that wirelessly connects to my alarm system, that gives me piece of mind that if I'm not home the fire dept will be alerted. It's great and all if I'm home, but if I'm not home, a standard smoke detector is nearly useless. The house will burn down, and my cat will probably die. At least with a monitored solution there is a better chance of saving the structure and pets.
I've been wanting to look at connecting my other smoke detectors to an arduino board so it can send me a SMS or email if it goes off. I'll do the same with methane detectors and a hydrogen detector where I have a flooded lead acid battery bank. Having basic smoke detectors is minimum code, it never hurts to go above and beyond. It's great and all if they can save your life, but if they can save your property too, then bonus.
Though when it comes to fire, prevention is key. The smoke detectors are simply a final layer of defense. You can follow electrical/fire codes, but it's still possible for a piece of equipment to fail and catch on fire, or for some freak accident to happen like the cat knocking over a mirror that happens to be placed perfectly so the sun burns the curtains or something whacked like that. Also proof that cats can be evil. LOL
Oh and garage... yes it's something I've overlooked but I should really put a monitored smoke detector in there... especially since it's attached to the house. In fact it's probably code.
Old 07-05-2012, 12:43 PM   #11
Its not code here in TX to have one in the garage. Thats where my fire started and even now as they are rebuilding, I asked about putting one in there, they said no, there is no need to. I'll be putting my own one in after we move back in.
Old 07-06-2012, 02:30 AM   #12
The problem with a smoke detector or smoke alarm is the dust acumulation that is possible. See if you can get a rate of rise 135° F heat detector to report to your panel.
Old 07-06-2012, 07:48 PM   #13
Wire Chewer
Yeah I was thinking that too actually, especially considering I'll be eventually turning that into a wood shop. So heat detector may be better. Could be as simple as a thermostat set to a high temperature, actually. That's what we use at work for low/high temp alarms for most of our buildings.
Old 07-07-2012, 07:54 PM   #14
Rate of rise heat detectors will detect the fixed temp (suggest 135°F) and a fast increase of temp.
Old 10-28-2012, 08:30 PM   #15
Great idea to check it every 6 months!
Also have a Carbon monoxide sensor is a good idea!
Jess_718 is offline   Reply With Quote
smoke test & combustion test?..what to look for?? millerheater HVAC 0 11-27-2010 11:44 PM
Smoke Detectors on Different Circuits Mililani Electrical 13 10-17-2010 07:35 PM
Tying in new 120v smoke detectors in an addition to existing ones... matthewschrag Electrical 1 08-20-2010 11:43 AM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 10:22 AM
Smoke Detectors / CO Detector Bocolo Electrical 9 02-17-2009 06:12 AM
