Sledge Hammer With Fiberglass Handle... How Indestructible Are They? - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Old 04-11-2011, 09:01 AM   #1
Sledge hammer with fiberglass handle... How indestructible are they?
Hi all:
I bought a 10lb sledge hammer with fiberglass handle. I have seen these hammer being used on home renovation shows and they seem pretty indestructible.
I was using the sledge hammer and attempt to demolish a huge piece of concrete the other day. I was doing it very close beside a fence and my aims are a bit off because I constantly worry about hitting the fence. Anyway, I overshot my target a couple of times, meaning more than one time, the hammer did not hit the concrete directly and the handle did instead. At the end, I left quite a few scars on the handle (about 3, maybe 1/8 inch deep, 2~3 inches away from the hammer)
So, here is my question: I still have a long way to go in my demolition project. The handle seems to still be in pretty good shape and doesn't seem to have any crack. Should I be worried about the hammer or can I keep using it? Would the hammer fail? If it would fail, would there be any early sign I should look out for?
thanks
xusword is offline   Reply With Quote
Old 04-11-2011, 10:27 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 386
Originally Posted by xusword View Post
Hi all:
thanks
I think you will be fine, just keep using it, that type of handle can take a lot of punishment, it won't just break like wood.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 04-11-2011, 01:07 PM   #3
Furd's Avatar
I agree with the above. If you wanted to protect the handle then you could wrap several layers of self-vulcanizing rubber tape (electrical rubber tape) for about six inches under the head. Don't use plastic tape, the rubber tape is what was once used under the cloth "friction" tape for electrical work and is still used for large bolted connections.
Furd is offline   Reply With Quote
Old 04-14-2011, 10:13 PM   #4
Remodeling Contractor
Fiberglass handles will start to look like a frayed rope when they begin to fail. But I wouldn't worry- you would need to miss that concrete all day hitting it with the handle to even begin to have a problem with it.
eisert is offline   Reply With Quote
rotary hammer drill or standard hammer gramps416 Tools 24 04-23-2013 01:34 PM
cellulose over blown in fiberglass? deerhunter Building & Construction 1 10-29-2010 10:16 PM
Screen/Storm Door Handle Height Steven Z. General DIY Discussions 2 11-22-2009 04:38 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Sillcock handle replacement jlbovo Landscaping & Lawn Care 7 08-04-2009 01:16 PM
