Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Safety
Old 04-21-2013, 01:08 PM   #1
Is it safe?
When ripping long boards on a table saw, it is not uncommon to have a 2nd man support the outfeed correct? My boss will tell the 2nd man to pull the piece through for the last few inches. I contend that this is unsafe and always use a push stick when i am operating the saw. It is an issue because now my helper has attempted to pull a piece through without me knowing a few times. He thinks it is standard procedure because he saw the boss do it.
Has anyone else seen this technique?
one cut is offline   Reply With Quote
Old 04-21-2013, 01:43 PM   #2
JOATMON
ddawg16's Avatar
Is it safe?
I do it all the time....in fact, my 10 year old son is good at it....as long as the piece stays flat....no issues. If your worried, then you should have the guard on.....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 04-21-2013, 02:51 PM   #3
Is it safe?
If you have someone helping that knows what there doing it's a whole lot easyer for them to pull then for you to push while trying to hold a stick and keep the board down tight to the table.
Please edit your profile so it shows your location!
No one here knows exactly where on the planet you may be so how can we ansewer a code, building, or insulation question without it?
Old 04-21-2013, 03:54 PM   #4
Civil Engineer
Is it safe?
I never have a helper available, so I ALWAYS use a roller table (built with a rolling pin) to support the board when ripping long pieces. I push it through with a push stick, but if I had a helper who understood that it is essential to keep the board straight when pulling, no problem.
Old 04-21-2013, 04:27 PM   #5
Is it safe?
I see. I guess my only problem would be having a helper who knows what they are doing.
Old 04-21-2013, 09:44 PM   #6
Is it safe?
i did a lot of 2x4's, ripping them to 1". i pushed half, and pulled the other half. NO ISSUES what so ever. no helper.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is online now   Reply With Quote
Old 04-21-2013, 10:01 PM   #7
Is it safe?
Ive ripped miles of wood and solid surface on the table saw, this procedure has just never seemed right to me. I will stick to doing it my way... perhaps until i feel comfortable with my helper. Thanks all.
Old 04-22-2013, 12:07 PM   #8
gravity always wins
Is it safe?
I hate when a helper decides to start pulling. I want control of the lumber until it exits the saw. When somebody is helping my instructions are that he is to stand there with his palms up and support the material, I will decide where and how fast it goes. If he pulls and runs it crooked or pinches it, there is only one way it's going to go.... towards me.
Old 04-22-2013, 01:00 PM   #9
Jack of all - master none
hyunelan2's Avatar
Is it safe?
The safety issue of pulling, is that you are grabbing onto the board to pull it. Should the blade bind up and yank the wood back (kickback), there is a chance that the helper may have his/her hands be pulled into the saw blade. Also, when you're pulling the board there is a greater chance you're going to curve the cut, leading to a stronger possibility of kickback.
When I have a non-experienced helper holding the outfeed of the board, I make them hold open-palmed, palm up. That way they can't pull or guide the board, just support it. Outfeed rollers are my typical use though.
Search "table saw kickback" on youtube if you want to see some wood go flying.
hyunelan2 is offline   Reply With Quote
ShieldsUP! (staying safe on the internet!) DangerMouse PC Repairs & Upgrades 3 07-08-2012 10:40 PM
No combination for safe aminus21 Building & Construction 3 03-16-2011 08:32 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Help Me.....installing Wall Safe shaw Carpentry 7 10-01-2006 05:50 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
