Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Safety
Old 05-20-2009, 09:35 PM   #1
Learning by Doing
Leah Frances's Avatar
My first electrical shock - MAN, am I dumb.
No burns, no harm, no foul? While trying to force a rec box back into its opening I touched the contacts of the single pole switch.
ZZZZZZZZap.
Tonight I am forcing myself to write on the whiteboard fifty times:
DO NOT DO ANY WORK ON ENERGIZED CIRCUITS
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-20-2009, 09:42 PM   #2
Electrical Contractor
Did you forget to put the note up in front of the panel?
Glad to hear you are ok.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 05-20-2009, 09:55 PM   #3
nap
You talking to me?
nap's Avatar
did you just add your sig line or was it a prophetic statement from before?
Old 05-20-2009, 10:25 PM   #4
Learning by Doing
Sig line's been there for months - since the last time I did something stupid.
I DO have my panel box tagged out. I even cut the power when I drilled a hole in wall that I thought some wires might run through (and they did).
Low blood sugar moment? I need some excuse.
Old 05-20-2009, 11:08 PM   #5
Repetition can do that too. I was doing dielectric test on a series of big line capacitors. Like 24" long by 12" high and rated at 1,200 V. Megger tested with 500 V. The process was a) remove bus bars, b) test capacitor, c) discharge 500 V charge with a resistor, d) reinstall bus bars.
a, b, c, d
a, b, c, d
a, b, c, d
a, b, d
All I remember is that one moment I was hunched over inside the big piece of equipment getting ready to re-install the bus bar, the next thing I knew I was halfway across the factory going, "What happened?" There was no passage of time between those two points. It definitely got my attention.
mwpiper is offline   Reply With Quote
Old 05-21-2009, 09:44 AM   #6
Joe F's Avatar
Experience is a tough teacher, you get the test first, then the lesson.
Glad you're OK.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 05-21-2009, 10:52 AM   #7
the Musigician
DangerMouse's Avatar
yup, i think c) would be a REAL important thing to not forget! *yeowch*
glad yer still with us!
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 05-21-2009, 07:02 PM   #8
not to encourage you, but I've seen and done myself, run electrical tape around the recepticle before placeing in the box, of course turning off the power first is best.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 05-21-2009, 09:39 PM   #9
Learning by Doing
I've been on the fence about wrapping contacts on recs and switches with electrical tape. I have been known to use it if I was really cramming things in a gang box to make sure nothing shorted side to side. But I don't do it as a rule with a singleton because, well, I HATE it when I open up an old box with a switch wrapped in some gummy tape.
I WILL NOT WORK ON ENERGIZED CIRCUITS...
Old 05-28-2009, 11:00 PM   #10
I have been wrapping all receptacles and switches with tape since forever. I am always leary of the screws holding the recep into the box coming loose. Of course using non-metallic boxes would solve that problem, but not the problem of a misplaced finger.
BTW, how do you "tag out" a residential panel? Do you mean just placing a note on the panel, or a piece of tape over the breaker or what?
I know these cannot be locked out.
FW
KE2KB is offline   Reply With Quote
Old 05-29-2009, 10:20 AM   #11
My goodness, I got my first shock when I was maybe 12 years old (and many more in the intervening 50 years).
I see you are in Easton. So was I until recently. I still own my house there.
Old 05-29-2009, 10:33 AM   #12
I've gotten amazingly few shocks, considering my history of working and playing with electricity.
I am 53 years old and can probably haven't received more than a dozen shocks, most of them on the light side.
The worst ones we used to get as kids were from a defective refrigerator, right across the chest when we touched a steam pipe at the same time as the fridge handle.
Not knowing anything about electricity, my parents didn't realize there was anything wrong with the fridge, so they just taped the handle with electrical tape.
This was no leakage current. It was the full 115V. I recall once having to push a friend off when she got hung. We were very lucky no one was seriously hurt or died!
If there had been GFCI in those days, none of that would have happened. We would have understood that there was a problem because the GFCI would have kept tripping, and called an electrician, who would have told us to get a new refrigerator.
I guess my mom or dad should have called an electrician anyway.
We learn from our mistakes, as long as our mistakes don't kill us!
FW
Old 05-29-2009, 11:24 AM   #13
It's actually been quite a while since my last shocking experience (well, with electricity anyway). I've been doing everything from electronics to house wiring since I was a kid so I guess I'm getting better at working hot.
The worst shock I ever got was when I was in the Navy. While troubleshooting a transmitter problem I got my hand across 2300 volts. Made a nice little hole going in and going out.
Old 05-29-2009, 12:09 PM   #14
Newbie Bill
I learned to be scared of electricity as a kid. I got my first shock when I was plugging in something and the prongs were bent. So I took my finger and squeezed the prongs to fit in the outlet and inserted the plug. Zzzaaapp! I remember that lesson everytime I plug something into an outlet.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 05-30-2009, 10:29 AM   #15
Old School
cabinetman's Avatar
I've welded screw drivers to panels, got zapped by 110V, 220V and 3PH. The worst shock I ever got was when I was a kid and got the juice off a running lawnmower from the little shutoff lever to the sparkplug. Oh wait, there was a time I got whammed by a coil wire off my car, and an AC capacitor. I guess it's a toss up. My arm is just tingling thinking about it.
cabinetman is offline   Reply With Quote
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 09:15 PM
Nail gun shock injuries dswan388 Roofing 11 11-24-2008 07:34 PM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 09:59 AM
