Information On Safety Equip - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Old 08-31-2012, 09:45 AM   #1
Information on safety equip
Hello,I am looking for information about respirators-specifically for use with expanding polyurethane spray foam,and also for using when mixing concrete grout or similiar material.Appreciate comments from anyone working in these industries,and DIY homeowners-anyone with experience using these products.Thank you!
Rmankty is offline   Reply With Quote
Old 09-07-2012, 08:58 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
For things that emit vapors, you want to use a respirator with organic vapor cartridges. For particulates like concrete dust, mold spores, drywall dust or asbestos, you want to use P100 cartidges. A good respirator "system" will allow you to stack filter cartidges. In some cases it is good to have a system that allows you to install a prefilter to help prolong the life of the primary filter. All of these cartidges and filters need to be used with a half or full face respirator. Ususally rated by NIOSH as N95. It is important to select a respirator that fits your face properly. If you can't get a seal around your face, then the respirator is totally useless. You must also change the filter cartridges regularly to be effective. P100s clog with dust, so you won't get all the air through them that you should which is tough on the user. Organic vapor cartridges lose their effectiveness when the absorption material inside of them gets saturated.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
Rmankty (09-07-2012)
Looking for "what to charge" Information Mark Harvey General DIY Discussions 16 03-07-2012 06:58 AM
Service Entrance Safety goaskandy Electrical 0 09-09-2011 03:00 PM
Safety Arms for Bilco-style basement exterior doors? mark2741 Building & Construction 1 04-07-2010 07:46 PM
No safety glasses? soundog Site Help and Suggestions 9 02-23-2010 08:25 AM
