Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Safety
Old 05-13-2010, 05:58 PM   #1
Household Handyman
How to test shelving, , , ,
So, the other day I put up four (4) shelves in a very small room, like 42" x 96". Two shelves on each end. This is to be a child's playroom off a patio. I had finished the last shelf, which was a lower one, and was cleaning up the dust from drilling the drywall. After a good sweeping I was using a damp cloth to wipe the newly installed Pergo-type flooring while squatted down. YEP! I just stood straight up catching the front bottom edge of the higher shelf on that end. After quickly sitting down and getting my senses back I did check the shelf, it did not move-any at all. I finished and proceed to go home about 11:oo A.M. About 4:30 P.M. while on the way to my g'son's ball game the back/left side of my neck really starts hurting. Wednesday night was HELL (can I say that here?). Thursday A.M. I put in an early call to the Chiropractor and they tell me to come in ASAP. X-rays are fine, but they tell me I have jammed my neck down so hard it may take 3-4 weeks to get over it. Daily massage in this area with the ultrasound thingy (that's wonderful) for one week. BUT--the shelf didn't move any. Don't speak behind me for a while, I'm not turning to listen to you. David
Old 06-20-2010, 12:33 AM   #2
General Contractor
Or you could put a bunch of weight on it, see if it collapses.
KennMacMoragh is offline   Reply With Quote
Old 07-03-2010, 05:42 PM   #3
It was a dark and stormy
Yoyizit's Avatar
Originally Posted by anna38 View Post
Since this is going to be your childs playroom, safety should be the most important factor. I'd definitely test the shelves out with some heavy objects over night to make sure they are sturdy. Better safe than sorry!
The 'industry wide Safety Factor is 4' [so says/said Hillman Hardware's site], so if the shelves hold 30# I'd load them to 120#. And leave them for a while; apparently this makes a difference.
For personal safety, SFs of 10 or more are used.
Old 07-04-2010, 08:41 AM   #4
Super Moderator
I hope your neck problems go away soon. An auto mechanic friend actually cracked a vertebrae
when he stood up quickly under a to low hoist.
Thank you for the reminder to always be careful.--Mike--
Old 07-04-2010, 09:50 AM   #5
Household Handyman
Update: This was a customers job, my "baby" is now 36 and I cannot afford his "playrooms" anymore. I just thought I was going to have a sore neck for 3-4 weeks and would be fine- - - NOT! A later MRI revealed "facets" in my neck were jammed together, or something like that, and irritated. Heck, I was irritated also. Injections into the facet joints-have you ever had that done?, not comfortable at all. Twelve-inch (12") long needle, 1/2 gallon of fluids being pumped into the joints--or so it felt like it. Things are much better now regardless of the Doctor stating: "At your AGE you need to stop doing things like this". Heck, Doc, if all I had to do was walk around wearing that little white jacket, with all those young pretty nurses I wouldn't be doing things like this! David
The Following User Says Thank You to Thurman For This Useful Post:
oh'mike (07-04-2010)
Old 07-04-2010, 11:20 AM   #6
Super Moderator
This age thing can really get my goat. If you want to do something and you can---why not do it?
I catch my helper running to take heavy things before I can grab them.
I know he means well--but damn I hate it!!!
How to test new plumbing work for leaks Gusaroo Plumbing 5 07-14-2012 03:06 AM
New test being conducted! Still hvac issue! MrShadetree0222 HVAC 24 10-21-2008 11:44 PM
Test kit for shower pan...HELPPPPP! tverhoef Plumbing 7 02-27-2008 11:12 AM
Radon Test! handy man88 Plumbing 2 10-18-2007 08:38 PM
