How To Ruin Your Day - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Old 07-27-2013, 09:10 PM   #1
Plumber_Michael's Avatar
How to ruin your day
This tank was so swollen I had to tear a wall out to pull it from a mechanical closet. Had all but exploded, but luckily the city meter had no check valve. Save yourself the trouble and change a t&p when it leaks, or just paint that bad boy up like a rocket and prepare for lift off
You don't have to be able to spell "plumber" to be one.
Plumber_Michael is offline   Reply With Quote
The Following 2 Users Say Thank You to Plumber_Michael For This Useful Post:
gregzoll (07-27-2013), hvactech126 (08-18-2013)
Old 07-28-2013, 05:41 AM   #2
DIY staff
Rewards Points: 7,174
Yikes------------
Old 07-28-2013, 09:27 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,500
Sorry....but I don't see what the problem is.
Seems like a natural thing to remove the PRV outlet pipe and install a gate valve.
BTW.....the above comment is about as sarcastic as I can get.....I recall some of the 'tests' Myth Busters did with hot water tanks....they launched a lot better than some of their home made rockets.
Old 07-28-2013, 09:57 AM   #4
They installed the tank in a narrow closet and positioned the t&p up against a wall so it couldn't pop. And putting a valve where a relief valve once was is a silly idea. People like that make me shine in my field though =]
Old 07-31-2013, 01:30 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
The person that did that should watch these videos.
Old 08-02-2013, 04:13 AM   #6
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Why even go through all that trouble, just solder a cap right on the end of it and call it a day.
This seems like something the mythbusters would do. Funny thing is, this on it's own probably wont do much... BUT *IF* there is a fault that causes too much pressure, that's where the real problem is. A faulty thermostat could have that thing in orbit.
Old 08-06-2013, 11:32 AM   #7
I wouldn't count on it not doing much. It would depend on other factors. Consider a house on municipal water with a backflow preventer (check valve) on the supply. Now happy homeowner installs a water heater without an expansion tank and closes off the TP valve. When the water heater comes on the pressure is going to build. Something is likely to break. Faucet blown apart? Split pipe? It's going to end badly, even if it is not a catastrophic failure of the tank. If it happens when no-one is around..............
Old 08-08-2013, 06:16 PM   #8
Wire Chewer
Rewards Points: 90
Well, this valve is strictly for emergency, 99.9% of the time, water never needs to escape. Never seen an install with a check valve at the incoming supply... but if there is one I suppose that could cause weird pressure issues as the water heats, and that valve may be more likely to be needed to drain. In a case where it drains regularly you'd definitely want to lead it to a drain.
Either way, definitely don't want to block it! It's like not having smoke alarms. Chances are they'll never be needed but you still want them and want to make sure they work!
Old 09-16-2013, 09:25 AM   #9
Originally Posted by oh'mike View Post
Yikes------------
Lol the best reply!
eliciasam1 is offline   Reply With Quote
Old 03-04-2014, 07:39 AM   #10
[QUOTE=Maintenance 6;1223416]The person that did that should watch these videos.
so true :D
Lillu is offline   Reply With Quote
Is this mason about to ruin my house?? Chris74 Concrete, Stone & Masonry 8 04-25-2013 06:38 AM
Refinishing furniture blunder. Did i just ruin my piece of furniture? wessidemike Carpentry 6 03-09-2012 12:54 PM
Does PVC cement freeze and ruin?? 4just1don Plumbing 5 01-14-2010 07:08 PM
Do renters ruin a neighborhood? ConstantChange Off Topic 17 10-26-2009 01:05 AM
Did I ruin my deck? jzinckgra General DIY Discussions 3 07-31-2008 08:49 AM
