Heated Afghan - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Old 02-14-2015, 07:41 PM   #1
Rewards Points: 2,152
Heated afghan
Loved this heated afghan one of my kids gave me. Perfect for cold mornings or evenings so I don't have to heat the entire house.
The adjustable switch has been blinking today. It does that if I've unpluged it from blanket but not the wall. I thought I'd bumped it getting up and down. I've reset it by unplugging it then plugging it back in and it would be fine for a while.
I just noticed the cord almost snapped off right where it goes into the adjustable switch. It was just hanging on by a wire.
Would that have shocked me if I had touched the wires accidently?
Its about 7 yrs old and so cozy I'd buy another but not if this could happen again and shock me.
Startingover is online now   Reply With Quote
Old 02-14-2015, 08:11 PM   #2
DIY staff
Rewards Points: 7,174
A picture of the wire would help---also--does it have a transformer?
Startingover (02-14-2015)
Old 02-14-2015, 08:45 PM   #3
Old 02-14-2015, 08:56 PM   #4
DIY staff
does it have a plug in transformer or does it work with batteries?
Old 02-14-2015, 09:03 PM   #5
It plugs into the wall just like a big electric blanket or a heating pad.
(I didn't know what a transformer was)
Old 02-15-2015, 06:17 AM   #6
DIY staff
You cell phone uses a transformer---does the plug have a box or something that will change the 110 volt wall current into ,safer, 12Volt ? If the unit runs off of 110 volt (I doubt it) then the broken cord would be very dangerous--
If the current is changed (transformed)into low voltage--then the broken cord will not be likely to zap you---
The control box should be able to be opened--so the wires can be reattached properly--
Startingover (02-15-2015)
Old 02-15-2015, 11:26 AM   #7
Rewards Points: 808
That heated throw is just a smaller version of an electric blanket. 120 volts, no transformer, no batteries. Yes, those exposed wires could shock you.
IslandGuy is offline   Reply With Quote
The Following User Says Thank You to IslandGuy For This Useful Post:
Startingover (02-16-2015)
Old 02-15-2015, 01:03 PM   #8
Rewards Points: 268
Yep. I have the exact same cord on our electric blanket. Can probably buy it on its own. That one looks to be completely toast and I would throw it out.
In fact I think I have 2 of those cords with the control on it around here. If you were close I'd tell you to come take them off my hands! :-)
Marqed97 is offline   Reply With Quote
The Following User Says Thank You to Marqed97 For This Useful Post:
Old 02-16-2015, 07:37 AM   #9
I'll contact Co. for replacement cord. Thanks for the idea!
Marqed, very kind offer if we lived closer.
Must be design flaw since I don't use it much and am careful with it.
Does bathroom fan vent duct need insulation when in a heated space? Studly Remodeling 8 04-04-2014 11:30 PM
Heated Floors Affecting Grout question Ted Uy Flooring 12 08-29-2009 12:45 PM
Heated tile ... really worth it? alvanos Flooring 27 01-11-2009 12:35 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 02:51 PM
