#1 |
Gloves for gasoline
Hi;
When we had the long power outage due to Sandy, I was handling small amounts of gasoline while pouring from can into generator. So I started using standard disposable gloves. They seemed to work ok for very short exposures, but I would really like to have a good pair of gloves that I could keep with the generator to use while pouring gas. I have been searching for such a pair, and it seems that nitrile is the material of choice, but all I can find are the thin disposable ones. It would be more environmental friendly, and safer if I could just get a decent pair that will last a few years. It really annoys me that everything today is disposable. Just keep filling up the landfills with non-degradable plastics. That's one reason I use rechargeable batteries wherever possible. Any ideas? Thanks FW
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#2 |
Gloves for gasoline
I share your annoyance with disposable things, but a handful of nitrile gloves really aren't making a difference, except as a matter of principle. Sometimes you have to let pragmatism take over.
Especially with the amount of times you'd have to use these thigns. One or two power outages a year, a few fillups per outage? Maybe buy a better can and funnel that don't spill as much
#3 |
Gloves for gasoline
The label will read - ATLAS Nitrile TOUGH NT370BBK for large size - made in Vietnam.
#4 |
Gloves for gasoline
Thanks for the info.
I would like to go with the Atlas Nitrile, but not sure which size to get. It's going to be either L or XL. My palm measurement is 4.5" across at the widest point (the base of the thumb), and 7.7" from the tip of my middle finger to the wrist. Makes sense to get the 4-pak from Amazon, as it's only about twice the cost of a single pair. I think I can use these gloves for a lot of other work as well. FW
#5 |
Gloves for gasoline
I'd like to know how your getting any gas on your hands in the first place?
I own 3, lawn mowers, 2, generators, 2, weedwackers, gas powered hedger, and never once have gotten gas on my hands. If I did I'd wipe it off with a rag or go wash my hands, no recycling, no waste. |
| The Following User Says Thank You to joecaption For This Useful Post: | oh'mike (01-09-2013) |
#6 | |
Gloves for gasolineQuote:
Some may say "shame on you" but no shame as much money I spend at ACE, my favorite small hardware store. Get a grip, you bet. Until they get some age one can pick a needle from a hard surface. My son that bow hunts wasn't interested until he tried them and now doesn't go without a pair. The only negative I've found is in warmer weather ones hands can get a little sweaty. OH, forgot one other negative. iphones don't do well so I snip the end off of pinkie finger. Tried pointer on first pair and pinkie is better for a couple of reasons. Last edited by Fairview; 01-09-2013 at 07:30 PM. |
#7 | |
Sure, I can just wash my hands, but the smell of gas remains on them for some time, and I don't like it. In addition, my skin dries out and cracks. I am going to start using a funnel and pouring the gas directly from the can, sans spout. The spout and its cap will be used only to cap the can. It's amazing that those spouts are allowed on the market. I tried one bran-new, never used yesterday and it failed to open. I ended up breaking the spring off in the process, then finally managing to open it. Piece of junk. But as I said, I could just go out and get myself a couple of good cans, then no problem. FW edit: Realized that I didn't need to keep the spout inverted in the can to properly seal it. Just keep the little cap on the bottom and replace the spout in the pour position. It's a really stupid design, but it's what I've got to work with for now.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by KE2KB; 01-10-2013 at 03:20 PM. |
| Display Modes | |
| Disposable Glove Recs? Fed Up w/Home Depot Cheap Shredders! | Lovegasoline | Painting | 8 | 07-15-2012 08:04 PM |
| Gloves | dmathis | Tools | 3 | 01-26-2010 08:33 PM |
| Work Gloves | jamiedolan | Electrical | 9 | 01-27-2009 08:30 PM |
| Cut Resistant gloves? | ADKstorm | Building & Construction | 3 | 04-23-2008 03:14 PM |
| What gloves to wear when working with electrical? | twilightcall | Electrical | 7 | 01-04-2008 06:34 PM |
