Gas Fireplace Leak - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Old 01-01-2012, 06:21 PM   #1
Gas fireplace leak
I have three very old freestanding heaters that sit in front of closed-off fireplaces. They are all heated by gas with pipes running through the floorboards and under the house. One with fake logs has smelled of gas since I moved in. I turned the valve parallel to the pipe and it still smells of gas.
1) How can I turn it off?
2) Am I gonna die?
Thanks.
arion is offline   Reply With Quote
Old 01-01-2012, 07:09 PM   #2
Rewards Points: 582
need more than that....some pictures would help....if you shut off valve and still smell gas the leak is somewhere else.....yes dangerous....
Old 01-01-2012, 07:18 PM   #3
Rewards Points: 13,260
If the gas fumes do not kill you the explosion will.
The first thing the gas company will do is tell you to get out of the house and do not touch anything. They should send someone right out, this is no joke.
Old 01-01-2012, 07:23 PM   #4
Rewards Points: 582
2) Am I gonna die?
Thanks.
how long have you been in the house....don't want to scare you but joe has a good point...but if you call gas company they will shut off your gas.....I would a plumber 1st they should find the leak repair or isolate it till it can be repaired..without affecting the heat...ben
Old 01-01-2012, 10:09 PM   #5
We've been here about eight months. Cripes, thanks, guys. I will call someone tomorrow. In the meantime, the windows are open.
Old 01-01-2012, 10:17 PM   #6
Something as simple as turning a light on, a piolit light, can cause it to blow.
Old 03-02-2012, 07:52 AM   #7
Rewards Points: 582
THIS IS AN OLD THREAD>>>WHATS UP
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 08:26 PM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 10:26 AM
Fireplace Smell ...help wanted ! jasonb72 General DIY Discussions 6 08-26-2010 07:02 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
