-   Safety (http://www.diychatroom.com/f45/)
-   -   Gas fireplace leak (http://www.diychatroom.com/f45/gas-fireplace-leak-128430/)
arion 01-01-2012 06:21 PM
Gas fireplace leak
I have three very old freestanding heaters that sit in front of closed-off fireplaces. They are all heated by gas with pipes running through the floorboards and under the house. One with fake logs has smelled of gas since I moved in. I turned the valve parallel to the pipe and it still smells of gas.
1) How can I turn it off?
2) Am I gonna die?
Thanks.
ben's plumbing 01-01-2012 07:09 PM
need more than that....some pictures would help....if you shut off valve and still smell gas the leak is somewhere else.....yes dangerous....
joecaption 01-01-2012 07:18 PM
If the gas fumes do not kill you the explosion will.
The first thing the gas company will do is tell you to get out of the house and do not touch anything. They should send someone right out, this is no joke.
ben's plumbing 01-01-2012 07:23 PM
2) Am I gonna die?
Thanks.
how long have you been in the house....don't want to scare you but joe has a good point...but if you call gas company they will shut off your gas.....I would a plumber 1st they should find the leak repair or isolate it till it can be repaired..without affecting the heat...ben
arion 01-01-2012 10:09 PM
We've been here about eight months. Cripes, thanks, guys. I will call someone tomorrow. In the meantime, the windows are open.
joecaption 01-01-2012 10:17 PM
Something as simple as turning a light on, a piolit light, can cause it to blow.
ben's plumbing 03-02-2012 07:52 AM
THIS IS AN OLD THREAD>>>WHATS UP:yes:
