Gas Cooktop Flush With Countertop - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Old 07-14-2014, 10:46 PM   #1
Rewards Points: 111
Gas cooktop flush with countertop
While installing new kitchen cabinets, I noticed my floor slopes quite a lot. I ended up with 2" shims under the lowest side. Because of this, if I don't shim the stove, the top of the burner grills will be just about flush with the top of the granite countertop, or maybe 1/4" lower. Is this dangerous? I think the granite should be okay, but I'm concerned about the plywood sub-counter and the side of the cabinet itself (MDF).
I could of course shim the stove higher, but it would reduce the already small gap to the vent hood, plus I like the idea of sliding pots easily between the burner and counter.
Granite isn't installed yet, but this image shows the plywood.
ebalsley is offline   Reply With Quote
Old 07-14-2014, 11:42 PM   #2
Rewards Points: 14,290
#1 If the floor was that far off it should have been dealt with first before any other work was done.
There is no heat hot enough on a stove on the outside to cause a safety issue.
Old 07-14-2014, 11:47 PM   #3
There is no heat hot enough on a stove on the outside to cause a safety issue, it's going to look like poop if it's not lifted some how.
Old 07-14-2014, 11:47 PM   #4
There is no heat hot enough on a stove on the outside to cause a safety issue, it's just going to look like poop if it's not lifted some how.
Old 07-14-2014, 11:48 PM   #5
Old 08-04-2014, 12:30 AM   #6
Rewards Points: 111
After looking at the granite for a week, I've decided it doesn't look good, so I'm going to raise the stove an inch.
On a related note, I started thinking about oven heat on the cabinet sides... There is only 1/2" clearance between the oven and the cabinet. But according to some sources, the auto ignition point of MDF is 425 F, which is well above what I expect on the outside of the oven. Anyway, I'll just buy a fire extinguisher and try to quit worrying.
How to enlarge hole in countertop for new cooktop KCMike Kitchen & Bath Remodeling 9 12-28-2012 05:07 PM
New glass cooktop too small for hole in granite countertop smcc1123 Appliances 1 06-25-2012 09:47 AM
How to install countertop over washer and dryer R V Dunai Remodeling 13 08-21-2011 02:07 PM
Cooktop color? hgtv Interior Decorating 2 07-20-2010 11:49 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 07:05 PM
