While installing new kitchen cabinets, I noticed my floor slopes quite a lot. I ended up with 2" shims under the lowest side. Because of this, if I don't shim the stove, the top of the burner grills will be just about flush with the top of the granite countertop, or maybe 1/4" lower. Is this dangerous? I think the granite should be okay, but I'm concerned about the plywood sub-counter and the side of the cabinet itself (MDF).
I could of course shim the stove higher, but it would reduce the already small gap to the vent hood, plus I like the idea of sliding pots easily between the burner and counter.
Granite isn't installed yet, but this image shows the plywood.
#1 If the floor was that far off it should have been dealt with first before any other work was done.
There is no heat hot enough on a stove on the outside to cause a safety issue.
There is no heat hot enough on a stove on the outside to cause a safety issue, it's going to look like poop if it's not lifted some how.
There is no heat hot enough on a stove on the outside to cause a safety issue, it's just going to look like poop if it's not lifted some how.
After looking at the granite for a week, I've decided it doesn't look good, so I'm going to raise the stove an inch.
On a related note, I started thinking about oven heat on the cabinet sides... There is only 1/2" clearance between the oven and the cabinet. But according to some sources, the auto ignition point of MDF is 425 F, which is well above what I expect on the outside of the oven. Anyway, I'll just buy a fire extinguisher and try to quit worrying.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
