Garage Door Security! - Safety - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Old 08-12-2011, 08:32 PM   #16
Rewards Points: 558
Wow you guys don’t have a garage door latch on your doors? Up here all garage doors have a sliding latch which would be installed by the garage door manufacture and the latch slides right into the track to lock the door.
they are like $ 5.00
epson is offline   Reply With Quote
Old 08-12-2011, 08:36 PM   #17
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
I can lift it from outside, but it's just there's not much grip so it's hard to do. The cord does not really release anything, it just pulls on the chain which pulls the door up/down. I can also just grab one of the center hinges of the door and pull up. The torsion bar makes this quite effortless. A crook could probably stick a crow bar under, lift a bit, then do the rest by hand.
Well, not anymore. I went overkill with those chains and U bolts, but you can never be too overkill when it comes to combating crooks.
Old 08-12-2011, 09:02 PM   #18
Learning by Doing
Leah Frances's Avatar
Originally Posted by epson View Post
Wow you guys donít have a garage door latch on your doors? Up here all garage doors have a sliding latch which would be installed by the garage door manufacture and the latch slides right into the track to lock the door.
We have one of these on our garage doors. It connects to a handle in the center of the door and has a lock - when we bought the house we had it keyed the same as our entry door locks.
But my garage isn't connected to my house; so it's not quite the security worry....
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-12-2011, 09:12 PM   #19
Rewards Points: 558
The one I mean is installed on the inside near the track and slides into a slot in the track. No key required but it does have a hole to put a pad lock if needed.
This is what you have
these have cables
Old 08-12-2011, 09:17 PM   #20
Learning by Doing
these have cables
Yeah, mine is the same, except it is connected by bars to a handle in the middle of the door. Turning the handle rotates the 'tabs' out of the slots in the track. I'll shoot a pic tomorrow. Too late to go tromping out to the garage in my PJs.
Old 08-12-2011, 09:20 PM   #21
Rewards Points: 558
yeah you can either use lock bars or cables on these...
this is how its installed and locked
Old 08-12-2011, 11:05 PM   #22
Remodeler
Rewards Points: 324
Sounds like you need a new opener.
I have installed and repaired hundreds of openers and have never seen one that would allow the door to be lifted manually without first tripping the emergency release. Either something is broken, worn out or not installed correctly. Most would not even close the door without the door solidly connected to the opener trolley. A properly adjusted door wants to stay open, the opener has to push it at least partway down before gravity will take over.
The timer mechanism and all the extra locking chains kinda negate the purpose of even having the door opener. If you have to get out to unlock, then close and re-lock you may as well just remove it and install a slide latch. Not saying that is a bad thing but I kinda like just pushing the button when it is sub zero or pouring rain.
A modern basic opener will have rolling code technology, auto reversing, and safety photo eyes. It will actually lock the door in the closed position, can be had for around $130 and is an easy diy project.
iamrfixit is online now   Reply With Quote
Old 08-12-2011, 11:16 PM   #23
Wire Chewer
Rewards Points: 126
I seen those, and I have also seen fully manual doors have a handle and key in the center (outside). Mine did not have that setup though. Suppose that could have been another way of doing it as well. Either way, nobody is going to come into my garage very easily now. If they manage it, their effort wont really have been worth it. It's not like I have bars of gold in there lol.
Old 08-12-2011, 11:22 PM   #24
Wire Chewer
Rewards Points: 126
Not sure how old this opener is, but it was probably not a very expensive one. At one point I thought the motor was burnt as it suddenly stopped working when the door was open. So I closed it manually. Next day it worked. It "closed" the door (chain was moving to bring the "hook" to the close position), then I hit the button again and it opened, then I closed it again. But after this whole incident, it occurred to me that if I was able to close it manually when it stopped working, then I probably can open it manually, and sure enough, I can.
But yeah at this point the auto opener is kinda pointless, though I don't plan on putting my car in there anymore. I want to eventually turn it into a shop and having the car in there makes it really messy with the sand and salt, not to mention with the heat, the salt eats at the car faster. It was a nice luxery, but think I'll do without like I did for the years before.
Old 11-19-2011, 09:05 AM   #25
Rewards Points: 87
This is something often not thought of, but a garage door is VERY easy to get in. I forgot to lock my car last night, someone stole the garage door opener and also opened the door and left it open all night. Nothing was stolen, but they'll most likely be back.
If they had not stole the opener, they could simply get another and try all the frequencies until it works... so having the wireless opener active may not be so much a good idea.
Another security issue, even with the opener unplugged, a garage door is VERY easy to open. You simply have to lift the door.
What I will do is get some heavy duty bolts, chain and hooks, so I can chain the door so it can't open.
Home owners, double check your garage door security, you'd be surprised how easy it is to break into!
My security system also protects my garage door.
You must live in a high crime area.
It is difficult for me to see where someone could raise your door if the opener is intact because you sure can't mine. I have a horman.
TGMcCallie is offline   Reply With Quote
Old 11-19-2011, 08:58 PM   #26
I had to go back to the original post after reading the rest of the thread. First, a dumb question. Have ever read your owner's manual on correct operation and maintenance of your opener?
There is no way you can open that door by simply lifting it from the outside if the emergency latch is properly engaged to the trolley that raises and lowers the door.
Manual latches are not normally installed on powered doors, but they can be added for a nominal cost. Adding chains, bolts, clamps, etc. is unnecessary!
The chances of anyone guessing your DIP switch settings, or trying all the possible combinations, is difficult at best, if not impossible, for the average thief, even on one of the old systems.
Second, if you have a garage, why was your car outside, and unlocked with the opener inside? Would it not be far more secure for your vehicle to be inside your garage, behind a garage door that's closed and secured. That is of course if the opener trolley is properly engaged!
If you leave your vehicle outside with a garage door opener inside, even with the doors locked on the vehicle, you are asking for a security breech! A determined thief would simply break a side window on your car and open the door with the opener! My vehicles are never left outside.
Get your opener properly set up and don't leave your opener I your vehicle! Simpler the going through the added expense of chains, timers, and the like, don't you think?
CATliftTech is offline   Reply With Quote
Old 11-19-2011, 09:19 PM   #27
Wire Chewer
Rewards Points: 126
It came with the house, no manual. Just figured it was the way it is. Though before I tried to open it manually I did figure it locked, but when I found out it does not, did not figure it was suppose to. Guess one day I could fix that, though I don't see anything obvious that would stop it from opening.
It was summer when it happened, so that's why the car was outside. I since got a security system, so I'm not as worried now. I actually hope they try, because the cops will show up. Though I have a security sign on the lawn and stickers on the doors/windows, so they'd be pretty dumb if they tried.
I plan to eventually turn the garage into a shop so I wont be using it for my car, so it's not a big deal to just undo the latches manually.
Old 12-19-2011, 12:09 AM   #28
Location: 5944 Coral Ridge Drive Suite 158 Coral Springs, FL 33076
- Sorry for all that happened, but I must say you were lucky for this time. Itís better to be cautious in future. Please add on the strong safety devices for your door and use the proper locking systems to avoid such instances in future. You should double check the garage door security as we usually have tendencies to ignore it.
sflockandsafe is offline   Reply With Quote
Old 12-19-2011, 07:19 PM   #29
raylo32's Avatar
Rewards Points: 1,284
Also, if you have a home alarm system, it is easy to add a set of contacts to the garage door.
raylo32 is offline   Reply With Quote
Old 02-16-2012, 03:04 AM   #30
pacowilson's Avatar
It's possible to install some PIR lights, switches. In addition, put some alarm stickers on the door.
PIR lights (switches) can work individually, you can install it in front of your door, when it detect the movement, it will turn on the light.
The other possible way, try to install an alarm system. If you already got, then you can get door/window magnetic contact (reed switches) for the garage door.
pacowilson is offline   Reply With Quote
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
