Emergency Heat/gas Generator Safety - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Old 12-24-2013, 12:15 PM   #1
Hvac Pro
yuri's Avatar
Rewards Points: 1,452
Emergency heat/gas generator safety
Very sad story but people need to be very careful if using a generator if they have no power. Get a new CO detector. Fumes must have seeped in around some windows or a dryer vent or whatever.
http://news.ca.msn.com/canada/two-de...s-in-newcastle
Old 12-24-2013, 01:29 PM   #2
Rewards Points: 13,300
We just had two people die in the same building 24 hours apart from a generator running to close to the building. By the time they figured out what killed the first one it was to late.
Old 12-24-2013, 02:33 PM   #3
Hvac Pro
yuri's Avatar
Kinda scary cuz I got one. My garage roof is vented open to the atmosphere on the sides and I have not had to use the generator. I will make sure the hole in the wall by the centra vac exhaust that I run the cord thru is sealed perfect. When you are a HVAC guy you sometimes think CO won't get you as you work with gas all day and fumes but complacency kills.
The Following User Says Thank You to yuri For This Useful Post:
Tek1 (02-17-2014)
Emergency heat/gas generator safety yuri General DIY Discussions 4 12-24-2013 03:40 PM
Oil Furnace Emergency shut off switch location? LarryNH914 HVAC 19 06-28-2012 03:47 PM
Commercial Building with 277 Volt Exit & Emergency Lights Perry401 Electrical 24 01-20-2012 09:33 AM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 02:17 PM
Aux and Emergency CPH settings indvid HVAC 2 03-02-2009 04:31 PM
