Dryer- No Exhaust - Safety - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Equipment & Safety > Safety
Old 01-11-2011, 10:47 PM   #1
dryer- no exhaust
I just bought a house that came with a washer and dryer in the garage. The dryer does NOT have an exhaust line, and isn't on an exterior wall... I know the obvious answer: yes, it needs to be done, but how, is it dyi, if not- how much is it gonna hurt my wallet?
OtisDriftwood is offline   Reply With Quote
Old 01-12-2011, 12:13 AM   #2
Civil Engineer
Rewards Points: 4,568
Do you have a gas or electric dryer? A gas dryer for sure needs a vent, cost is beyond my knowledge. An electric dryer can be vented into the garage to the best of my knowledge. It would be important to install a lint trap on the exhaust side so you don't blow lint all over the garage, however I know of no code requirement for venting an ELECTRIC dryer.
Old 01-12-2011, 12:18 AM   #3
Experienced
Jackofall1's Avatar
Vent both electric and gas to the outside, especially if you experience temps below freezing, the humidity in the exhausted air will condense on every cold surface, causing very good conditions for mold growth. It can somewhat easily be done on your own. Just need to route 4" round ducting to outside wall and add a flapper vent.
The Following User Says Thank You to Jackofall1 For This Useful Post:
Gary in WA (01-12-2011)
Old 01-12-2011, 11:32 AM   #4
It's electric (boogie woogie woogie). I fear it might be tricky to do, because it's on an interior wall, in a nook (not a straight shot to an exterior wall). I guess I really need to map it out from above in the attic as to how tight of a turn it has to make? I also think there may be decking over that wall in the attic.
Also, I live in south Louisiana, so deep freezes are rare, but humidity is not.
Old 01-12-2011, 07:42 PM   #5
Household Handyman
Rewards Points: 1,408
South Louisiana=probably NO basement. Do you have a crawlspace? IF so, then you can run the vent under the floor as long as it does vent to the outside of the foundation wall. IF no crawlspace--back to square 1.
Old 01-12-2011, 09:36 PM   #6
Yeah, negative on the basement or crawl space. Attic is the only wall access.
Old 01-13-2011, 12:48 PM   #7
I can tie my own shoes
algored2deth's Avatar
Really, this is not too bad of a job. Just use rigid duct/pipe and wall mounted flap and get it to the outside asap. If the line becomes really long, you made need to add an assist blower. Depends on how much air your dryer can push. Only need 4" pipe. Try to make the run straight as possible. The more turns, the more you lose air pressure over distance.
Don't use the accordion type stuff. Reason being that lint will catch inside of it and be a possible fire hazard. It also sucks to clean. Whatever you do, make sure that you put in something that can be easier to clean. You may need to buy a 4" circle bit though for the flap install on the wall.
algored2deth is offline   Reply With Quote
Old 01-13-2011, 02:13 PM   #8
Chicago, IL
Michael Thomas's Avatar
Electric clothes dryers (except condensing types) should not be vented to interior
The installation instructions for every conventional (non-condensing) electric dryer which I have reviewed contain a requirement similar to the following:
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 08-12-2011, 12:10 AM   #9
Hi... Guys , I am new to this forum, I want to know that what is going on. What are you talking about. Hope to get support from you guys.
Scoobie2 is offline   Reply With Quote
Old 10-02-2011, 10:49 PM   #10
renovation contractor
vent
Keep in mind that a 90 degree elbow is equivilent to about 30 ft of straight run.
Also a slight downward angle would be good
Also upsizing to 5 inch may be considered on a long run.
B.D.R. is offline   Reply With Quote
Old 10-03-2011, 01:24 PM   #11
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Scoobie, there are several issues touched on in those three sentences: Difference between venting a electric vs gas dryer, moisture issues, and venting to the outside.
Your best bet would be to start your own thread with any specific questions. They will be more likely to be seen and answered.
Dryer vent and fan exhaust bromeo710 HVAC 1 12-13-2010 05:53 PM
how to avoid condensation in exterior wall when enclosing washer/dryer pemn Remodeling 6 12-01-2010 03:35 PM
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 09:47 PM
Dryer exhaust/Bathroom exhaust fan nclooten HVAC 4 11-09-2009 11:45 AM
Dryer exhaust question Felipon Appliances 6 02-03-2008 12:29 PM
