#1 |
JOATMON
Dihydrogen Monoxice Dangers
Warning to all....it's in our water supply....
http://www.dhmo.org/facts.html Dihydrogen Monoxide (DHMO) is a colorless and odorless chemical compound, also referred to by some as Dihydrogen Oxide, Hydrogen Hydroxide, Hydronium Hydroxide, or simply Hydric acid. Its basis is the highly reactive hydroxyl radical, a species shown to mutate DNA, denature proteins, disrupt cell membranes, and chemically alter critical neurotransmitters. The atomic components of DHMO are found in a number of caustic, explosive and poisonous compounds such as Sulfuric Acid, Nitroglycerine and Ethyl Alcohol.[/quote] Each year, Dihydrogen Monoxide is a known causative component in many thousands of deaths and is a major contributor to millions upon millions of dollars in damage to property and the environment. Some of the known perils of Dihydrogen Monoxide are:
http://www.snopes.com/science/dhmo.asp
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by ddawg16; 12-11-2012 at 03:30 PM. |
#2 |
Your info is correct.
#3 |
JOATMON
If Snoops says it is......it must be.....
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by ddawg16; 12-11-2012 at 06:48 PM. |
#4 |
Scary, though...
#5 |
Super Moderator
A school district in California banned Dihydromonoxide after a board member sited the dangers and the number of children who died each year because of lung exposure---
New members: Adding your location to your profile helps in many ways.--M-- |
| Display Modes | |
| Dangers of no Ground Wire | jgiannis | Electrical | 2 | 06-20-2012 05:25 PM |
| What are the dangers? | Mop in Hand | Electrical | 6 | 07-13-2011 10:16 AM |
| Pesticide Dangers | handy man88 | Landscaping & Lawn Care | 2 | 02-13-2011 09:02 PM |
| Drywall dangers? | Clankpot | Drywall & Plaster | 4 | 08-01-2010 10:48 AM |
| how dangers is an ungrounded receptical | kenny357 | Electrical | 9 | 09-20-2007 10:18 PM |
