Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Safety
Old 11-15-2010, 03:28 PM   #16
Moderator
kwikfishron's Avatar
circular saw kickback
Well, if you use a Sawzall I sure hope you know where all of your electrical and plumbing is at.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 11-15-2010, 03:37 PM   #17
the Musigician
DangerMouse's Avatar
Ya cut at an angle and skim the surface with a short bi-metal blade, not a 12" ripper stabbed in! LOL
Like I said, I barely nicked the FOAM under the 3/4" T1-11.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 11-15-2010, 11:27 PM   #18
firehawkmph's Avatar
I used to use a circular saw for cutting into aluminum siding when putting in new windows. It takes a steady hand. The biggest problem is usually you are on some sort of ladder while doing this. Don't overreach with the saw. Cut what you can reach without stretching, then move up and start again. Blade depth shallow as others have mentioned.
I now use a saw I bought at sears a number of years ago on a whim. It has two blades that counter rotate against each other. The motor looks like an angle grinder. It leaves a very clean cut and is a lot of easier to control. Good eye protection is a must. The aluminum chips that come off fly everywhere and they are on the large side. Wear some thin gloves too. I have a bunch of pairs of craftsmen work gloves. The cut siding is sharp.
Good luck,
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 11-16-2010, 05:24 AM   #19
the Musigician
It sure is! You just brush your hand against it and you're got a nice scratch or gash.....
Wear those gloves or be very, very careful!
DM
Circular saw -- 6 1/2" Vs 7 1/4" & cordless Vs corded whataboutj Tools 9 02-26-2010 05:20 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Considering a circular driveway proofer Landscaping & Lawn Care 1 06-20-2009 08:53 AM
Using circular saw blade in a chop saw rayem723 Carpentry 5 10-27-2008 09:08 PM
ripping safely with a circular saw bobbyC777 Safety 6 02-20-2008 10:16 AM
