Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Safety
Old 03-18-2010, 12:39 AM   #1
circular saw kickback
I'm thinking about cutting some vertical siding with my new circular saw. Since I can't see behind the siding, I might hit a nail or staple by accident.
How serious would a kickback be from hitting a nail? Could I control it if I hole the saw with both hands? How badly would it damage the blade?
darsunt is offline   Reply With Quote
Old 03-18-2010, 01:26 AM   #2
(the original)
Put a Dewalt DW3191 blade on your saw. It's made for remodeling, cuts right through nails.
Yes, hold the saw with both hands when making cuts on a vertical surface. Set the blade depth just to the thickness of the siding and don't try to cut too fast or reach too far. Keep it in control.
ratherbefishin' is offline   Reply With Quote
Old 04-16-2010, 03:55 AM   #3
agree, kick back on a circular saw is normally nothing major. the worst you will do to the blade is break a tooth. the above suggestion on blades is good and or my favorite are from diablo. for what you're doing 1-2 $10 blades should be plenty.
racebum is offline   Reply With Quote
Old 04-16-2010, 09:57 AM   #4
yes, i would buy a couple cheaper blades cause breaking a tooth on a $10 blade vs. a high end blade....you would rather get the high end blade fixed rather than pitching it and thats just more money
miles11we is offline   Reply With Quote
Old 04-24-2010, 11:50 PM   #5
Remodeling Contractor
I'm a carpenter. Don't worry about breaking a tooth on your blade. They still cut. I use my circ saw blades on major demo jobs till all the teeth are gone.
As far as the kickback, it dependes on how strong you are. If you are worried about the kickback, use 2 hands. The more confident you are using your tools, the safer you'll end up being while using them.
eisert is offline   Reply With Quote
Old 06-18-2010, 02:51 PM   #6
Handyman
Picturing eisert cutting wood with one tooth on the blade
canadaclub is offline   Reply With Quote
Old 11-11-2010, 09:31 AM   #7
old guy contractor
tcleve4911's Avatar
They make those demo blades for that exact purpose.........
tcleve4911 is offline   Reply With Quote
Old 11-11-2010, 10:10 AM   #8
STAFF
BigJim's Avatar
Watch your eyes though, a nail when cut has no direction and that sucker hurts when it hits you so watch your eyes, you only get one chance with them.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
oh'mike (11-11-2010)
Old 11-11-2010, 12:11 PM   #9
the Musigician
DangerMouse's Avatar
I'd think it'd be safer and easier with a reciprocating saw.... but what do I know?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 11-15-2010, 02:41 AM   #10
Household Handyman
Proper blade depth on this application is critical IMO. Setting the blade depth to just cut through the material will tend to cut through the nails where setting the blade depth too deep will tend to "lift" the nails as it cuts them.
Old 11-15-2010, 07:48 AM   #11
Jack of all - master none
hyunelan2's Avatar
DM
I agree, but if he only wants to cut through the siding and not whatever is underneath it (sheathing, etc) - it might be hard to do that with a reciprocating saw.
P.S. reciprocating saw is easily my favorite power tool.
hyunelan2 is offline   Reply With Quote
Old 11-15-2010, 07:57 AM   #12
the Musigician
I had to cut a hole through T1-11 and used my sawzall..... I only nicked the foam board on the other side a couple of times.
With a lapping siding, I imagine it'd be much harder to control depth with a circular saw?
DM
Old 11-15-2010, 11:22 AM   #13
STAFF
BigJim's Avatar
DM
You are right, with the lap siding it would be harder to control the circular saw and the sheathing would almost certainly be cut unless you really really know your stuff.
Jim
Old 11-15-2010, 12:14 PM   #14
(the original)
That's when you tack up a board for the saw base to ride on and maintain depth of cut......
Recip's fine, too, but I find I can get a straighter, faster cut with a circular.
The Following 2 Users Say Thank You to ratherbefishin' For This Useful Post:
BigJim (11-15-2010), DangerMouse (11-15-2010)
Old 11-15-2010, 12:57 PM   #15
the Musigician
Darn good idea, Thanks! (of course, you have to repair the nail holes, but it's still better than trying it the other ways.)
DM
Circular saw -- 6 1/2" Vs 7 1/4" & cordless Vs corded whataboutj Tools 9 02-26-2010 05:20 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Considering a circular driveway proofer Landscaping & Lawn Care 1 06-20-2009 08:53 AM
Using circular saw blade in a chop saw rayem723 Carpentry 5 10-27-2008 09:08 PM
ripping safely with a circular saw bobbyC777 Safety 6 02-20-2008 10:16 AM
