-   Safety (http://www.diychatroom.com/f45/)
-   -   circular saw kickback (http://www.diychatroom.com/f45/circular-saw-kickback-67073/)
darsunt 03-17-2010 11:39 PM
I'm thinking about cutting some vertical siding with my new circular saw. Since I can't see behind the siding, I might hit a nail or staple by accident.
How serious would a kickback be from hitting a nail? Could I control it if I hole the saw with both hands? How badly would it damage the blade?
ratherbefishin' 03-18-2010 12:26 AM
Put a Dewalt DW3191 blade on your saw. It's made for remodeling, cuts right through nails.
Yes, hold the saw with both hands when making cuts on a vertical surface. Set the blade depth just to the thickness of the siding and don't try to cut too fast or reach too far. Keep it in control.
racebum 04-16-2010 02:55 AM
agree, kick back on a circular saw is normally nothing major. the worst you will do to the blade is break a tooth. the above suggestion on blades is good and or my favorite are from diablo. for what you're doing 1-2 $10 blades should be plenty.
miles11we 04-16-2010 08:57 AM
yes, i would buy a couple cheaper blades cause breaking a tooth on a $10 blade vs. a high end blade....you would rather get the high end blade fixed rather than pitching it and thats just more money
eisert 04-24-2010 10:50 PM
I'm a carpenter. Don't worry about breaking a tooth on your blade. They still cut. I use my circ saw blades on major demo jobs till all the teeth are gone.
As far as the kickback, it dependes on how strong you are. If you are worried about the kickback, use 2 hands. The more confident you are using your tools, the safer you'll end up being while using them.
canadaclub 06-18-2010 01:51 PM
Picturing eisert cutting wood with one tooth on the blade:laughing:
tcleve4911 11-11-2010 08:31 AM
They make those demo blades for that exact purpose.........
BigJim 11-11-2010 09:10 AM
Watch your eyes though, a nail when cut has no direction and that sucker hurts when it hits you so watch your eyes, you only get one chance with them.
DangerMouse 11-11-2010 11:11 AM
I'd think it'd be safer and easier with a reciprocating saw.... but what do I know?
DM
Thurman 11-15-2010 01:41 AM
Proper blade depth on this application is critical IMO. Setting the blade depth to just cut through the material will tend to cut through the nails where setting the blade depth too deep will tend to "lift" the nails as it cuts them.
hyunelan2 11-15-2010 06:48 AM
DM
I agree, but if he only wants to cut through the siding and not whatever is underneath it (sheathing, etc) - it might be hard to do that with a reciprocating saw.
P.S. reciprocating saw is easily my favorite power tool.
DangerMouse 11-15-2010 06:57 AM
I had to cut a hole through T1-11 and used my sawzall..... I only nicked the foam board on the other side a couple of times.
With a lapping siding, I imagine it'd be much harder to control depth with a circular saw?
DM
BigJim 11-15-2010 10:22 AM
DM
You are right, with the lap siding it would be harder to control the circular saw and the sheathing would almost certainly be cut unless you really really know your stuff.
ratherbefishin' 11-15-2010 11:14 AM
That's when you tack up a board for the saw base to ride on and maintain depth of cut......:yes:
Recip's fine, too, but I find I can get a straighter, faster cut with a circular.
DangerMouse 11-15-2010 11:57 AM
Darn good idea, Thanks! (of course, you have to repair the nail holes, but it's still better than trying it the other ways.)
DM
