Zinsser Perma-white - Painting - DIY Chatroom Home Improvement Forum
Old 07-03-2008, 09:34 PM   #1
Rewards Points: 123
Zinsser Perma-white
-- Mold & Mildew-Proof Interior Paint - Can I use this in a bathroom as an undercoat/primer on previously painted walls and new drywall prior to my final coat of paint?
jerome8283 is offline   Reply With Quote
Old 07-03-2008, 09:46 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
There is no need to use a mildew resistant paint as an undercoat
Mildew comes from the environment, not from underneath
(unless it's coming from behind the wall, but that's another issue)
Having Z's PW as the creamy mold and mildew resistant filling in your bathroom coatings Oreo cookie won't help fight mold and mildew
And although Z's PW is "self-priming", it does not make a good primer
The "self-priming" helps in the case of bathroom paint, as bathrooms are the most heinous environment for coatings
But it does not replace actual primer in a case like new drywall in a bathroom
slickshift is offline   Reply With Quote
Old 07-03-2008, 11:37 PM   #3
Rewards Points: 2,906
So far as I know, Zinsser's PermaWhite only comes in satin and semigloss, both of which are too smooth to make for a good primer.
PermaWhite doesn't dry to a rough enough surface to make a good primer. And, as SlickShift pointed out, the mildewcide in it is going to do no good whatever being under another top coat of paint.
Nestor_Kelebay is offline   Reply With Quote
ceiling not white cart Painting 7 06-22-2008 07:32 AM
White vs. Off White kristinnsmith Interior Decorating 7 05-27-2008 01:14 PM
Trim color and interior doors..white or off white? kristinnsmith Interior Decorating 3 04-22-2008 05:48 PM
Whatcha thinka NOT painting interior moulding white? Davo Interior Decorating 7 07-07-2007 07:58 PM
How do I get rid of Zinsser Perma White Smell kc2ahl Painting 7 06-24-2007 06:05 PM
