Old 10-12-2007, 12:57 PM   #1
Zinsser Bulls Eye Water Base Primer
Anyone used this product before? Zinsser Bulls Eye Water Base Primer? I am looking to prime some bare wood, door framing around closet before I paint it all white. I am trying to stay away from oil base paints. It states, Formulated to resist grain raise. All inputs are welcomed. Just hate painting with oil products... Thanks!
helpless handyman is offline   Reply With Quote
Old 10-12-2007, 03:33 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Bullseye Waterbase is supposed to be a low/no odor version on Bullseye 1-2-3...which is also water-based btw
If there are no knots, markings, or other potential bleed-through problems, and it's bare wood (no finish), then you can use a water-based primer
I personally don't find 1-2-3 too smelly, but I suppose some people are more sensitive to odors than others
slickshift is offline   Reply With Quote
Old 10-13-2007, 11:05 AM   #3
poppameth
Guest
Posts: n/a
Bullseye is definitely a cheapy version of 1-2-3 but it should work fine for what you are doing. Go for it.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Zinsser Primer on Wood Veneered Furniture cupcake Painting 3 10-05-2007 03:07 PM
water base poly over oil base poly pappabear Painting 3 08-24-2007 02:53 PM
water base over oil base csvharvest Painting 6 03-01-2007 07:12 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
