Old 10-11-2011, 08:04 PM   #1
caroln242's Avatar
Zinsser BIN Primer Sealer watery?
I just primed my closet walls and ceiling with Zinsser Bin Primer Sealer and have a question. It was so watery that it ran down my hands and arms and spattered everywhere. Is that normal for Zinsser or did I get a bad batch? I would have thought primer would be a thick product. As you can tell, I am "one of those people" that just paints and doesn't normally bother with the priming part so I'm unfamiliar with this type of primer. I used it specifically because it's supposed to hide odors and I have a hall closet that has some weird "old" smell I can't get rid of. I hope this Zinsser works!
If it's not supposed to be watery, I guess it won't do the job it's supposed to.
caroln242 is offline   Reply With Quote
Old 10-11-2011, 08:09 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Did you stir it- and stir it well? Bin settles out easily and fast- so the top is basically denatured alcohol.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-11-2011, 08:22 PM   #3
caroln242's Avatar
Oh, it was mixed very well. It was shook at the store and I stirred it before and several times during.
Old 10-11-2011, 08:27 PM   #4
Good- so yes- it is not like latex at all- it is thinner and needs more control. You can't just dip a brush deep and press it- it needs some finesse.
Zinsser makes about a billion primers- this is one. They all have different characteristics.
Bin is excellent for what it is good for- stain sealing, odor sealing and quick spot priming.
Spread thin and work quick- it dries very fast.
Old 10-11-2011, 08:58 PM   #5
caroln242's Avatar
Okay, that's good. I was afraid I got a hold of a bad batch or something. Hopefully Zinsser's Primer will live up to it's claim of odor blocking!
Thanks for your response...appreciate it.
Zinsser Primer Sealer igneous Painting 1 04-25-2010 06:45 PM
Zinsser primer not drying kevinkk Painting 9 12-17-2009 09:56 PM
using BIN Shellac Base Primer Sealer joefromcal Painting 10 05-04-2009 06:47 AM
Primer Sealer Oil or Water Based? petey Painting 7 05-11-2008 07:11 AM
Zinsser Primer on Wood Veneered Furniture cupcake Painting 3 10-05-2007 03:07 PM
