Zinsser Bin Lot Codes / Date Codes - Painting - DIY Chatroom Home Improvement Forum
Old 06-20-2011, 04:04 PM   #1
Zinsser bin lot codes / date codes
Hi. I have a quart of Zinsser b-i-n in front of me.
It's identified as LOT S13041 D
Can anyone tell me the date it was manufactured ?
Thank-you!
Crystal2 is offline   Reply With Quote
Old 06-20-2011, 08:16 PM   #2
The last digit is the month, 1, therefore January. January of 1304. Probably too old to use.
Honestly Crystal, there's no way to tell by that number alone. BIN does go bad. With the new high price of BIN, I would make every effort to use it, if it's good. Call Zinsser, they should be able to tell you. If it's been sitting that long, and they tell you it's good, stop at a paint store, bat your eyes, (sexist, I know) and ask them to shake it for you. BIN can get really sludgy on the bottom and difficult to stir in. I always have my BIN shaken, not stirred.
The Following 2 Users Say Thank You to jsheridan For This Useful Post:
Brushjockey (06-20-2011), hammerheart14 (06-21-2011)
Old 06-21-2011, 12:10 AM   #3
Rewards Points: 150
I'd definitly shake it for ya if you were hot and bashed your eyelids at me!!!!
hammerheart14 is offline   Reply With Quote
Old 06-21-2011, 04:15 AM   #4
NACE Coating Inspector
mustangmike3789's Avatar
all manufactures use different codes in there batch numbers. SW uses 2 types of numbers for some reason. ex...XM3280AG was made on the 328th day of 2010, & ROO845004H10 was made on 8/4/10 H being the month in this case. so much easier than putting a normal date on it i guess . if you do the eye lash thing for me, i may be able to help you with your batch#
mustangmike3789 is offline   Reply With Quote
Old 06-21-2011, 05:50 AM   #5
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
BIN isn't too difficult to tell when it's bad. If you shake it, give it a minute to settle and then open the can, you'll see bits of white floating around that have not dispersed into the solvent if it's bad.
Darkling Designs
poppameth is offline   Reply With Quote
Tags
zinsser bin lot date code
Four coats (2 Kilz Original AND 2 Zinsser BIN) Crystal2 Painting 23 02-21-2017 12:16 PM
Zinsser Cover Stain Sucks Lovegasoline Painting 38 01-20-2017 08:58 PM
Carrier Weathermaker SXi Codes 41 and 44 Knight78 HVAC 5 11-12-2010 06:18 AM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 10:55 AM
Where to find building codes? nimblemotors General DIY Discussions 5 06-27-2008 07:15 AM
