Zinsser 123 Water Based Primer - Dry Time - Painting - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 10:52 AM   #1
I have a project I am doing outside with the 123 Water Based Bulls Eye Primer. We have been having rain off and on and I am trying to get parts of the job completed between the bouts of rain.
On the label it says it takes 7 days to fully cure, does that mean I need to wait that long before it gets rained on?
Please tell me how long after it is applied before rain can come on it. I plan to paint it with latex after it has cured but can't get both done before rain will come again.
Thanks,
Randal
sharingsunshine is offline   Reply With Quote
Old 10-18-2011, 11:23 AM   #2
iminaquagmire's Avatar
Rewards Points: 338
The 7 days is the final cure time. You can put your topcoats on after 1 hour as long as it it dry. The topcoats should be exterior rated and dry for the specified time if they are exposed to rain.
iminaquagmire is offline   Reply With Quote
Old 10-18-2011, 11:55 AM   #3
Thanks for getting back to me. I understand the topcoat has to be exterior rated and dry the allotted time.
However, I need to know the primer requirements if I can't get to the topcoat due to other obligations. I don't want to put down the primer and lose my efforts when the rain comes a few hours later.
So if I could get a range of time the primer has to dry that would help me to plan accordingly between the rain showers.
Old 10-18-2011, 12:17 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
In typical ( warm, dry not to heavy application) situations 123 drys to be ready to recoat or get rained on in an hour.
Best to have the rain hold off a little while longer- but the stuff does dry fast. adjust times for humidity/coolness etc.
Top coats are usually at least 4 hrs to be rain safe.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-18-2011, 12:33 PM   #5
Thanks, that is exactly what I needed to know.
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 08:46 AM
installed new hot water tank and now we only get hot water if 2 sinks on at same time Terryh Plumbing 5 07-26-2010 04:54 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
