-   -   Zinsser 123 Water Based Primer - Dry Time (http://www.diychatroom.com/f4/zinsser-123-water-based-primer-dry-time-120478/)
sharingsunshine 10-18-2011 09:52 AM
I have a project I am doing outside with the 123 Water Based Bulls Eye Primer. We have been having rain off and on and I am trying to get parts of the job completed between the bouts of rain.
On the label it says it takes 7 days to fully cure, does that mean I need to wait that long before it gets rained on?
Please tell me how long after it is applied before rain can come on it. I plan to paint it with latex after it has cured but can't get both done before rain will come again.
Thanks,
Randal
iminaquagmire 10-18-2011 10:23 AM
The 7 days is the final cure time. You can put your topcoats on after 1 hour as long as it it dry. The topcoats should be exterior rated and dry for the specified time if they are exposed to rain.
sharingsunshine 10-18-2011 10:55 AM
Thanks for getting back to me. I understand the topcoat has to be exterior rated and dry the allotted time.
However, I need to know the primer requirements if I can't get to the topcoat due to other obligations. I don't want to put down the primer and lose my efforts when the rain comes a few hours later.
So if I could get a range of time the primer has to dry that would help me to plan accordingly between the rain showers.
Brushjockey 10-18-2011 11:17 AM
In typical ( warm, dry not to heavy application) situations 123 drys to be ready to recoat or get rained on in an hour.
Best to have the rain hold off a little while longer- but the stuff does dry fast. adjust times for humidity/coolness etc.
Top coats are usually at least 4 hrs to be rain safe.
sharingsunshine 10-18-2011 11:33 AM
Thanks, that is exactly what I needed to know.
