Zinsser 123 - Painting - DIY Chatroom Home Improvement Forum
Closed Thread
Old 03-28-2014, 09:15 PM   #1
Zinsser 123
Plan on using this for my primer this weekend. Are there any tips when applying this as far as type of roller? Should I just have to do one coat?? And after I prime, that is the best time to double check for defects and correct them also??? Then prime that area again ??? Thanks for any help
jobudiy is offline
Old 03-28-2014, 09:24 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
Use a good quality roller like a 1/2" nap (assuming you have smooth walls) Purdy White Dove. One coat is good. If you do any patching, then yes you should recoat over them. I always try to reroll instead of use a brush on touch ups as a brush can leave stroke marks which can reflect light differently than the rest of the wall would.
iminaquagmire is offline
The Following User Says Thank You to iminaquagmire For This Useful Post:
jobudiy (03-28-2014)
Old 03-28-2014, 10:15 PM   #3
Gymschu's Avatar
Rewards Points: 1,022
+1 on iminaquagmire's advice. 1-2-3 is a great primer. Depending on WHAT you are priming, it could be overkill for something like drywall where a standard drywall primer will suffice. 1-2-3 can certainly be used on drywall but its properties are more suited as a bonding primer on glossy surfaces. So, in a nutshell, what I am saying is that there are dozens of primers out there and each solves a specific problem.
Gymschu is offline
The Following User Says Thank You to Gymschu For This Useful Post:
iminaquagmire (03-28-2014)
Old 03-28-2014, 11:01 PM   #4
(the original)
Rewards Points: 756
+1 on 123 and White Dove. I only do small repair and remodel jobs anymore, and the great thing about 123 is that it bonds new and old surfaces better than most in its price range. All I have to do is knock down stipple on the old work with a pole sander, put on a coat of 123, and you can't tell through the finish coats which was old and which is new.
Overkill in some situations...yeah....but I consider it cheap insurance.
And, yes, you can see defects better after priming...skim where needed and spot prime, then you're ready to go.
ratherbefishin' is offline
Old 03-29-2014, 06:36 AM   #5
kwikfishron's Avatar
Rewards Points: 998
Sorry timothy300858, but you are suspended from our site. And the user name "jobudiy" is now banned also
kwikfishron is online now
The Following User Says Thank You to kwikfishron For This Useful Post:
iminaquagmire (03-29-2014)
Closed Thread
Four coats (2 Kilz Original AND 2 Zinsser BIN) Crystal2 Painting 23 02-21-2017 12:16 PM
Zinsser Cover Stain Sucks Lovegasoline Painting 38 01-20-2017 08:58 PM
Zinsser BIN Primer Sealer watery? caroln242 Painting 4 10-11-2011 07:58 PM
Zinsser 123 dry time question hyunelan2 Painting 6 02-08-2011 04:50 PM
Will joint compound stick to Zinsser 1-2-3? Lovegasoline Building & Construction 13 09-28-2009 10:55 AM
