Zinsler Primer On Exterior Cedar - Painting - DIY Chatroom Home Improvement Forum
Old 09-13-2013, 01:26 PM   #1
zinsler primer on exterior cedar
What do you think about the zinsler oil based primer for cedar siding?
Drmg42 is offline   Reply With Quote
Old 09-13-2013, 04:47 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 388
you mean Cover Stain by Zinsser?
Old 09-13-2013, 05:00 PM   #3
Yes, I need to prime some weathered areas before staining with solid color stain from Sherwin Williams
Old 09-13-2013, 07:09 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
I use it all the time. I thin it a tad as it goes on like peanut butter
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 09-13-2013, 07:14 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
If you are using an oil stain, it is usually not primed first. The stain needs to sink into the wood.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 09-13-2013, 08:10 PM   #6
Actually I'm not sure what to use! I know that I need to prime as I have some weathered and bare cedar and other areas that still have the solid stain intact.
Just looking for a solid, smooth cover!?
Old 09-14-2013, 07:34 AM   #7
Gymschu's Avatar
Rewards Points: 822
If you need to prime that's quite alright if you're using a latex based solid stain. Rarely do I prime cedar that is going to be stained, but, if it's really weathered, that's a good idea as plenty of tannins will leach through the topcoats in areas like that. Take a look at SW's Woodscapes.
Gymschu is online now   Reply With Quote
Old 09-14-2013, 09:52 AM   #8
Thank you for the help
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 07:47 AM
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 05:03 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 11:48 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
