Zinser 123 - Oil Or Latex? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 05:29 PM   #16
Rewards Points: 155
Originally Posted by jsheridan View Post
Check the paint time on the black tube. the last I heard that was being discontinued, are you getting a good deal on it?
I bought 3 or 4 tubes sometime back, of which I have two full tubes left. Last time I was at the BM distributor (a few days ago), it was almost $4 a tube. The tagged bin was there, but they were out of stock. I didn't ask, but maybe it was empty because it is being discontinued.
Paint time is 4-6 hours (oddly, the tube states "dries in 4-6 hrs., can be painted when cured"...not always the same thing).
Bob... is offline   Reply With Quote
Old 02-19-2013, 06:21 PM   #17
The last time I used the black tube, the paint time was 8 days, seriously. That was 3-4 years ago. I don't think it was the same as what you're using now. I read it in the middle of using and it blew my mind, and I switched up mid job.
Old 02-19-2013, 07:06 PM   #18
Rewards Points: 155
This caulk is Acrylic Urethane (it has the distributor's name on it...not BM's). The fine print calls it an elastomeric product. Since it doesn't specify cure time, I'll have to ask. Maybe the caulk you were using was siliconized latex? I know that can take 1-2 weeks to cure. I found that out the hard way too.
Old 02-19-2013, 07:26 PM   #19
No this was a high performance BM urethane caulk.
The Following User Says Thank You to jsheridan For This Useful Post:
Bob... (02-19-2013)
Old 02-19-2013, 08:47 PM   #20
Rewards Points: 155
Thanks for the heads up. I'll definitely make sure of cure times for whatever caulk I use.
And thanks to everyone in the thread for the valuable information. I appreciate it!
The Following User Says Thank You to Bob... For This Useful Post:
jsheridan (02-19-2013)
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Latex Enamel over Latex Semi-Gloss M910 Painting 2 07-29-2011 03:39 PM
oil to latex, proclassic vs behr GLS0628 Painting 2 06-23-2011 05:57 PM
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 10:33 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
