Zin Bullseye 123 Over Rustoleum Spray And Good To Go? - Painting - DIY Chatroom Home Improvement Forum
Old 09-21-2013, 11:08 AM   #1
Rewards Points: 89
Zin Bullseye 123 over Rustoleum Spray and good to go?
Back doors were painted with Rustoleum spray. Plan is to scuff, hit with a coat or two of Zin 123, and paint with Ben exterior. Will this work?
7.62 is offline   Reply With Quote
Old 09-21-2013, 03:13 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
As long as you don't miss any areas, one coat of primer is all you need. A lot of people here would recommend the 123, it is just about the best latex primer out there, but if it were me I would use Oil Coverstain.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 09-21-2013, 08:09 PM   #3
cdaniels's Avatar
The 1-2-3 should work pretty good but it takes a while to cure and adhere (I think the can says seven days).On doors I would go with oil Coverstain because of the abuse doors get and the possibility of weatherstripping sticking.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 09-22-2013, 03:55 PM   #4
Rewards Points: 89
Thanks. I will go with coverstain IF I can get it in a quart.
Spray FOAM - Stone Home Help Mozzy Insulation 2 04-11-2013 12:34 AM
Spray painting a metal front door - what paint?? hayman Painting 9 09-22-2012 06:15 PM
Spray System Recomendations? RHulsmeyer Painting 3 05-22-2012 10:50 PM
Anyone think spray painting door trim is a good idea? WoodmanFL Painting 2 02-05-2012 01:47 PM
Touch n' Foam (spray) 'Pro System' - good product? KatieAK Building & Construction 0 11-19-2009 07:59 PM
