Yellow Walls - Painting - DIY Chatroom Home Improvement Forum
Old 10-23-2010, 06:36 PM   #1
337
337's Avatar
Question
Yellow walls
Hi all, I'm new here
We just had the walls of a new house spray-painted white, apparently the walls are made of cast containing also recycled paper and the spray-paint turned yellow-ish.
I heard there was a (chlorine based liquid ?) product that can bleach this yellowish effect out without having to repeat the entire spray-paint job. Is anyone here familiar with it or has ever had this problem ?
I would be grateful for any information you can offer
337 is offline   Reply With Quote
Old 10-26-2010, 05:03 AM   #2
EU and US products can be as different as night and day. Personally if your home is new, I would be talking to my contractor.
By the way nice Avatar.
mark942 is offline   Reply With Quote
Old 10-26-2010, 09:37 PM   #3
337
337's Avatar
Lightbulb
Thanks Mark942
This is a new house and the contractor acknowledged the problem - the story is like this : The contractor hired a one-man company for the spray-painting, this was a young guy who came in, made a lot of unrelated mistakes and left the walls with large yellow patches on them, he then ran the floor-heating full power for 2 weeks insisting the spray-paint would dry out (on a light cast-wall of a 2 year old construction.... it was as dry as the dessert....).
I told him to return and sort things out, the then used some type of bleach rather than repainting but again - did a poor job and I had no idea what chemical he used.... but now I received a bottle from the contractor - who apologized since.
I'll post a picture in a couple of weeks - we are now in the middle of the move - so things are a bit messy and I may be offline for a few days...
Later
Old 11-24-2010, 01:09 AM   #4
337
337's Avatar
Finally the new house is starting to take on shape, although we are minimalists, we still had quite a bit of chaos....
The mystery liquid used to bleach the yellow patches left on our walls after a careless worker neglected to prime recycled cast, is a "Wall plaster cleaner". To all of you who may experience this in the future, here is a pic of the bottle below - sorry for the Dutch label....
Old 11-24-2010, 08:33 AM   #5
Rewards Points: 256
Go to this page and look at these pictures. Did your walls look like these pictures? How to separate colors on a wall
Steve
www.handpaintedbysteve.com
spraygunn is offline   Reply With Quote
Old 11-24-2010, 08:42 AM   #6
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
It sounds like bleed through. I highly doubt anything short of priming and re-painting is going to solve the problem.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 11-25-2010, 12:21 AM   #7
337
337's Avatar
My walls did not look like the pics, in that other thread the walls were actually painted in a different color, this was not the case with us - we had unpainted walls of recycled cast - and while normal white paint did not cause the same problem, spray-paint (structured) without priming turned yellowing. The cleaning fluid in the pic I posted solved the problem. I can no longer find pics of the walls - I formatted my private PC since....
Old 11-27-2010, 09:41 AM   #8
Matthewt1970's Avatar
Rewards Points: 1,098
You need to prime to seal in the bleedthrough and then repaint. Schellac (BIN) would be your best bet. An Oil base primer would hold it at bay for a while but you really need Schellac. Bleach may turn the surface white but it will just bleed back through.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 12:07 PM
Caulk on walls, priming, trouble with lines, and more! mrsjande Painting 7 09-10-2009 09:29 AM
Colors for adjoining walls wemwem Interior Decorating 3 01-24-2008 11:59 PM
Moisture on walls chrisr Building & Construction 1 01-20-2008 09:37 AM
