Yellow Colorwashing -want Tuscany Look - Painting - DIY Chatroom Home Improvement Forum
Old 09-19-2008, 09:19 AM   #1
Smile
yellow colorwashing -want tuscany look
I have just painted my room a beautiful bright yellow color. It is Sherwin Williams gusto gold. It's pretty, but I am going for the faux look and would like to make it more of a Tuscany feel. I tried to add a brown--bad news--tried a brighter yellow--barely visible. Should I try orange?? Just dont know what that second color should be to step it up a notch and add tecture. SO thankful for any advise.
wrsjk is offline   Reply With Quote
Old 09-19-2008, 06:48 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Are you mixing your second color with a glaze?
slickshift is offline   Reply With Quote
Old 09-21-2008, 08:33 PM   #3
I dont know should I/ Some said to and other said dont need to. Any suggestions? What does the glaze do? tks
Old 09-21-2008, 08:52 PM   #4
Pro Painter
For a wash, use glaze for two reasons. First, it extends the drying time, second it will soften the color to blend in with the base coat.
The color to use would be yellow/brown. Not straight brown.
joewho is offline   Reply With Quote
Old 09-22-2008, 05:10 AM   #5
slickshift's Avatar
Oh yes!
Don't use is straight
Mix it with a (clear) glaze 4:1 (glaze:paint)
That mix becomes your "glaze"
Old 09-22-2008, 01:07 PM   #6
Great thanks, I'll try it tonight. Is that the general rule for a glaze 4:1? Thanks.
Old 09-22-2008, 01:23 PM   #7
Another question....When doing a faux paint job what kind of paint should be on the wall and what should I mix the glaze with regarding a flat, satin or semi gloss. Does it matter or is it personal preference? Thanks
Old 09-23-2008, 12:45 PM   #8
Pro Painter
Flat paint should never be used as a base coat. Semi-gloss is the easiest to work with but satin/eggshell is also acceptable.
Old 09-24-2008, 07:11 AM   #9
This is such a great site...thank you all for you help. I mixed yellow and red paint to get the color I wanted (almost a rust color), added the glaze.....and it looks fantastic on my yellow walls! Thanks so much everyone.
Tags
faux painting
white paint turning yellow victor Painting 40 11-13-2012 09:09 PM
yellow flames on Hotpoint Range ajoantmug Plumbing 2 08-06-2009 08:02 PM
Yellow Jackets in house sporadically 20vtguy Pest Control 3 09-22-2008 09:34 AM
Pollen season and my new yellow porch dchaban Building & Construction 9 04-25-2008 12:18 PM
