Wrong Silicone On Trim, Paint Won't Stick - Painting - DIY Chatroom Home Improvement Forum
Old 01-11-2016, 05:13 PM   #1
Rewards Points: 36
Wrong silicone on trim, paint won't stick
I think I messed up and used the wrong silicon for trim and windows, paint is just not sticking to it at all.
This is the one that I used GE Silicon I
http://www.walmart.ca/en/ip/ge-silic.../6000193974395
How do I go about fixing this ? I did one coat of paint so far.
Can I buy proper silicon and just run it over ?
M4rtin is offline   Reply With Quote
Old 01-11-2016, 05:34 PM   #2
Jmayspaint's Avatar
Rewards Points: 522
Removing it is the ideal fix, but often you can get away with caulking over it. The thing is, a paintable caulk isn't going to bond to the silicone either. If you run a larger bead that can bond to the wood on either side of the existing bead, it can work ok.
Jmayspaint is online now   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
Colbyt (01-11-2016)
Old 01-11-2016, 06:12 PM   #3
Rewards Points: 5,434
Didn't know there was such a thing as the correct silly cone. Even if you remove it it can still cause adhesion problems unless you sand the area really well.
Entering your general location can help with answering a lot of times
ToolSeeker is online now   Reply With Quote
Old 01-11-2016, 07:05 PM   #4
Gymschu's Avatar
Rewards Points: 4,152
This has an outside chance of working but there's no guarantees. Prime the silicone with an oil-based bonding type primer such as Zinsser's Cover Stain. If you don't feel comfortable with the oil, try the Zinsser's latex 123. These type of primers stick to almost anything, even glass. Silicone is a fickle master, so this has a 50 - 50 chance of working. I've done it several times with success.
Giving us your general location helps us better help you!
Gymschu is online now   Reply With Quote
A few jokes... gma2rjc Off Topic 2512 Today 05:19 PM
Prepping old trim for fresh paint (chipping paint) housegsx Painting 6 11-18-2011 08:26 AM
Paint pull-up!?!? with BM Aura Bath & Spa, GE Silicone II, and PM Green tape DIYatHome Painting 8 12-12-2009 04:52 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
Which paint to use? Painting wood trim white Proulx06 Painting 11 04-09-2008 09:18 PM
