Wrong Caulk - Painting - DIY Chatroom Home Improvement Forum
Old 08-27-2008, 03:04 AM   #1
Wrong Caulk
Grabbed the wrong caulk at the store; meant to get "paintable" but instead got "window & door". Is there any way to get paint to stick to this stuff short of scraping it all off?
dwatkins8 is offline   Reply With Quote
Old 08-27-2008, 07:23 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
First off, how do you know that the caulking is non-paintable? Is it silicone?
- Build Well -
Old 08-27-2008, 03:00 PM   #3
Rewards Points: 2,906
DWatkins: The chances are that it is paintable. You won't do any harm by trying to paint it.
Most caulks are paintable. About the only caulk I can think of right now that isn't paintable are the ones made of silicone rubber.
Nestor_Kelebay is offline   Reply With Quote
Old 08-27-2008, 09:25 PM   #4
Yes it would be silicone rubber. I attempted to paint with latex and it just beaded up and did not stick. I don't even think that acetone will "etch" it so something will stick. When I discovered that I had the wrong caulk I looked at the tube which said non-paintable. What to do . . . what to do!?!?
Old 08-28-2008, 07:24 AM   #5
Check this out: http://www.thisoldhouse.com/toh/askt...597906,00.html
- Build Well -
Old 08-28-2008, 07:29 PM   #6
Thanks Atlantic, this is what I need. I have a lot of this to attempt to remove at the ceiling to wall joint on the exterior of my lanai. Better get started! If this does not work out then I will have to consider putting up some type of small ceiling molding to cover it and then paint.
Thanks again for the assistance.
D
Old 08-28-2008, 07:44 PM   #7
Tired, Cold, and Damp
slickshift's Avatar
Originally Posted by dwatkins8 View Post
...Is there any way to get paint to stick to this stuff short of scraping it all off?
Maybe.....
If you clean it well with isopropyl alcohol, then carefully paint with two light coats of Zinsser's BIN white pigmented shellac, you may get carefully applied paint to then stick to it
It's not a guaranteed fix, but I have used this method successfully numerous times
slickshift is offline   Reply With Quote
Old 08-31-2008, 01:27 PM   #8
Thank you, Slickshift, I will try this as well. It sounds possible that it will work. Let you know.
Grout before Caulk around bathtub? bsippl Building & Construction 6 08-19-2008 09:57 AM
How to caulk windows the RIGHT WAY? fritzycat1 Painting 3 09-10-2007 07:32 PM
Bathtub Caulk billinak Remodeling 17 05-27-2007 09:34 AM
Caulk Windows eric s General DIY Discussions 2 11-26-2006 09:45 PM
