Is It Worth It To Spar Urethane Over Flat Exterior Latex Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 04-19-2010, 09:41 AM   #1
Question
Is it worth it to spar urethane over flat exterior latex paint?
I've got a small exterior wall, plywood surface that's been primed and painted with flat exterior latex. If I want to give this more protection from the elements (water, sun, freezing) should I coat with a spar urethane or would it be better to just build up extra coats of the same exterior grade latex?
peterk312 is offline   Reply With Quote
Old 04-19-2010, 08:48 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
The spar urethane could actually peel and bubble the latex underneath. If you have a solid coat of paint on the wood, I would say you are protected.
Old 04-20-2010, 03:45 PM   #3
Matthew:
At another DIY forum, someone suggested the same to me. He said that the flat exterior was a bad idea if I was looking for the surface to be water repellent. He said better to go with a satin or semi-gloss, which I just painted over the flat. He said this would give just as much protection as a spar urethane. Hard to believe, but we'll see. Thanks for your reply.
Old 04-21-2010, 10:15 PM   #4
remodeling pro
Only if you enjoy sanding off coats of varnish every two years.
troubleseeker is offline   Reply With Quote
Tags
latex urethane
1st Steps in Painting? Qckrun Painting 7 12-15-2009 01:25 PM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Flat paint leeddsd Painting 4 03-16-2008 08:23 AM
Washable Flat or Eggshell Paint? Kyle Painting 6 09-14-2006 11:42 PM
