-   -   Is it worth it to spar urethane over flat exterior latex paint? (http://www.diychatroom.com/f4/worth-spar-urethane-over-flat-exterior-latex-paint-69350/)
peterk312 04-19-2010 09:41 AM
I've got a small exterior wall, plywood surface that's been primed and painted with flat exterior latex. If I want to give this more protection from the elements (water, sun, freezing) should I coat with a spar urethane or would it be better to just build up extra coats of the same exterior grade latex?
Matthewt1970 04-19-2010 08:48 PM
The spar urethane could actually peel and bubble the latex underneath. If you have a solid coat of paint on the wood, I would say you are protected.
peterk312 04-20-2010 03:45 PM
Matthew:
At another DIY forum, someone suggested the same to me. He said that the flat exterior was a bad idea if I was looking for the surface to be water repellent. He said better to go with a satin or semi-gloss, which I just painted over the flat. He said this would give just as much protection as a spar urethane. Hard to believe, but we'll see. Thanks for your reply.
troubleseeker 04-21-2010 10:15 PM
Only if you enjoy sanding off coats of varnish every two years.:no:
