Worse Than Primer And Paint In One? - Painting - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 01:17 AM   #1
Too Short? Cut it Again!
Worse Than Primer and Paint in One?
I couldn't sleep again for some reason so got up and plowed through a Menard's newspaper insert. I don't shop in box stores so do not often look but my eye caught an ad for Dutch Boy Maxbond and I got a hint of the next marketing gimmick.
Maxbond is advertised as an exclusive exterior no prep, no prime formula providing superior adhesion over dirty, chalky, previously painted or glossy surfaces.
What next? Shame on Sherwin Williams (Dutch Boy is their brand for the unwashed masses). I am sure it was the consumer wants to hear though. I guess the muddy look will be the new rage.
The Following User Says Thank You to user1007 For This Useful Post:
Nailbags (04-25-2013)
Old 04-24-2013, 02:29 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 616
unbelievable I am surprised they got the jump on Behr
Old 04-24-2013, 07:31 AM   #3
Roofmaster
Rewards Points: 2,210
Cmon guys, dont you believe in scrubbing bubbles?
The Following User Says Thank You to jagans For This Useful Post:
r0ckstarr (04-25-2013)
Old 04-24-2013, 08:17 AM   #4
Rewards Points: 14,312
What's next a paint you can apply with your sprinklers so you do not even have to get on a ladder or use a brush?
Gymschu (04-24-2013)
Old 04-24-2013, 08:32 AM   #5
Rewards Points: 101
Sweet, now I won't have to power wash dirty , chalky buildings anymore!
Can i apply directly over mold and mildew as well?
JMDPainting is offline   Reply With Quote
Old 04-24-2013, 09:12 AM   #6
Rewards Points: 394
The claims get more incredulous as time passes. This gives people the impression that they do not have to do anything, regarding cleaning, prep and priming.
Will22 is offline   Reply With Quote
Old 04-24-2013, 09:28 AM   #7
Gymschu's Avatar
Rewards Points: 1,032
The next step will being able to paint over PEELING paint with great results.
Old 04-24-2013, 04:19 PM   #8
chrisn's Avatar
Rewards Points: 616
Peel Bond ?
Old 04-25-2013, 08:50 AM   #9
Rewards Points: 394
People already try to do that, I assure you.
Old 04-25-2013, 09:18 AM   #10
Rewards Points: 626
Hey it was done in the old pink panther cartoons!
Nailbags is offline   Reply With Quote
Old 04-25-2013, 09:47 AM   #11
Rubbin walls since'79
Brushjockey's Avatar
Wait until they discover my patented WALLPAPER CANNON!
No prime , no glue (..) no worries!
Just pull the trigger!
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Will22 (04-26-2013)
Old 04-25-2013, 10:22 AM   #12
Matthewt1970's Avatar
Rewards Points: 1,098
Nothing beats the paint bomb. The trick is to put the can in the middle of the room for even coverage.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 04-25-2013, 10:23 AM   #13
r0ckstarr's Avatar
Rewards Points: 2,064
Self propelled electric paint roller. You hold it against the wall. It spins the paint on.
r0ckstarr is offline   Reply With Quote
Old 04-25-2013, 06:10 PM   #14
ltd
Rewards Points: 536
unwashed masses . I like that. is it ok if I steal that
ltd is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 10:33 PM
Fresh acrylic primer + paint not sticking paul_l Painting 12 09-23-2010 09:06 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
oil base paints NoExperience Painting 30 09-04-2008 05:37 AM
