Worried About Primer Color - Painting - DIY Chatroom Home Improvement Forum
Old 09-09-2011, 04:51 AM   #1
Worried about primer color
Long story short, I am painting over a dark sky blue bedroom with yellow stars all over it/ (we purchased the house like this)
I've cleaned it. Sanded it. Washed it down and spackled where needed. I found 3 cans of Zissner 123 bullseye in my garage and thought I hit jackpot since I didn't have to go out and purchase a primer.
I opened up the cans and they were medium gray in color. I know primers can be either white, gray or tinted to the color you will eventually paint HOWEVER this gray looks really dark and I'm wondering if I'll be able to paint a lighter color (peach or light yellow, even tan) over this primer or will I have to go over the walls again with a white primer? One coat of this gray stuff did cover the blue well.
I really want to get this right the first time since it's a project i'm doing without the husband glaring over me!
Any advice??
SherriGiron is offline   Reply With Quote
Old 09-09-2011, 07:24 AM   #2
A Little Of Everything
Rewards Points: 1,364
Sure, you can use it. Plan on using at least 2 coats of paint, perhaps 3. But don't worry, that's normal.
...and tell your husband to back off.
DrHicks is offline   Reply With Quote
Old 09-09-2011, 10:08 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
You probably could have just done 2 coats of paint to cover it although your spackle spots need 3.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 09-10-2011, 09:22 AM   #4
Too Short? Cut it Again!
Primer or new underlay and two coats of finish is the way it should be done. If your primer is that dark it may cause you problems and you might want to save for it for another project.
first coat of primer is on the drywall, but it's not pretty wengang1 Painting 14 12-25-2013 06:16 PM
Latex primer over oil base finish.. whalogreg Painting 6 01-28-2011 02:32 PM
New Roof Color Alto Roofing/Siding 3 08-27-2010 01:14 PM
help me pick a primer jheavner Painting 21 01-26-2009 11:30 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
