Wooden Deck Stripping - Painting - DIY Chatroom Home Improvement Forum
Old 08-25-2004, 10:53 AM   #1
Rewards Points: 14
Wooden deck stripping
Have a PT wooden deck with solid color stain. Would like to strip it and go with a transparent stain. What are chances of success? I was told by an experienced painter that he's never seen this work successfully, no matter what stripping agents are used. Once sealed by the solid color satin, it's almost impossible to 'unseal' and clean the wood so that it will accept the new stain. Comments?
handiandi is offline   Reply With Quote
Old 08-25-2004, 10:29 PM   #2
Contractor
If it were me I would first use an agressive stripper like aircraft remover, I'd follow with the best wood bleach that I could find. I'd be willing to do this twice. If the stripper removes everything on the first pass and the bleach does too, stop and proceed to YOUR finish. A good process like Snappy Nu Teak can work wonders.
Work a sample area first to check it out.
Teetorbilt is offline   Reply With Quote
Old 05-17-2005, 09:15 PM   #3
Which semi transparent deck stain to use
Can anyone recommend a good quality deck stain, semi transparent for a PT and Cedar deck. Was looking at the Flood product the other day, it is quite expensive, is it worth the money.
I live in the northeast, cold winters, plenty of the white stuff.
roadie is offline   Reply With Quote
Old 05-18-2005, 02:23 PM   #4
Contractor
A good rule of thumb is that you get what you pay for, don't expect much from cheap products. Flood is a good product and if applied properly should last about 3 yrs.
Old 05-23-2005, 09:34 PM   #5
Carpenter
DecksEtc's Avatar
I've always had success with the Cabot brand of wood stains.
Terry
DECKS Etc.
GardenStructure.com
DecksEtc is offline   Reply With Quote
Old 05-26-2005, 12:20 PM   #6
Rewards Points: 528
Handiandi,
I would heed the professional painters advice. I don't believe you could do the job yourself and get 100% satisfaction; it would be more like 50%. A professional might get 75%. Pressure treated wood changes and forms either convex or concave shapes and develops cracks after about 1-1/2 seasons. Trying to sand this down or using chemical strippers with the intention of putting down a new like finish using a transparent stain is in my opinion, foolhardy. Its a lot of work just to make the preparations to use another solid color stain.
My advice would be to repair and restain the troublesome areas using the same stain and add a light coat to the rest of the deck.
My PT deck lasted about 2 years that had a transparent stain. All the elements including the sun did enough damage to make me change my mind forever about using transparent stains. There is too much maintenance on maintaining the appearance of the deck you seek. Have you given it some thought about the new type of wood composites to use for decking? They are maintenance free. A bit expensive the last time I checked. But check it out anyway.
rjordan392 is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 07:12 PM
Are ther alternative to Wooden Post on Deck Foundation herbolaryo Carpentry 2 05-27-2007 07:55 AM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 09:50 PM
Firepit on elevated wooden deck handiandi Building & Construction 6 08-19-2004 11:25 PM
