Wood Trim Finishing Problems - Painting - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 11:59 AM   #1
Rewards Points: 410
Wood trim finishing problems
I am using Mini-wax polycrylic water based on new hickory trim( whole basement remodel ).
I am using foam brushes.
I am finding uneven surfaces and bubbles marks at times .
Basement temps are 64 f where I'm finishing the wood at.
I have a lot of wood to do and need to find the right technics.
High Gear is offline   Reply With Quote
Old 12-05-2010, 02:40 PM   #2
Rewards Points: 256
Hey Gear,
Gotta tell ya, I’ve never used foam brushes, however I’ve heard positive reports from others. Question: Did you stir or shake the polycrylic? And what specie of wood are you applying it on?
Steve
www.handpaintedbysteve.com
spraygunn is offline   Reply With Quote
Old 12-05-2010, 03:32 PM   #3
Air Bubbles can form in a foam brush application. Personally I would use a good quality Purdy brush. Also as commented by Steve, I would make sure the can had been STIRRED very well. You also might want to look at a mini roller and roll on as much as you can on your Hickory trim, then back brush to level out. This would be more along the lines of production painting.
http://www.purdycorp.com/catalog/min...amecover_combo
Good Luck.
mark942 is offline   Reply With Quote
Old 12-05-2010, 06:11 PM   #4
Rewards Points: 410
After some sanding/cussin ect , yeah I'm blaming the lions share on air
encapsulated in the foam brush.
I got out my Purdy brush and things are looking much better , then I see its
recommended so maybe .
Maybe in the right hands a foam brush is OK but I don't like them , don't
seem like much control, had to give it a try as some seem to like them..
Yeah I know better than to shake the can and am stirring it a good while.
I picked up some 220.320 and 600 paper and have #0000 steel wool for
the final buff.
No experience with waterbased poly and has been yrs since I played with
the oil based (and I seem to remember no problems then).
It seems to raise the grain on the first coat ( water based ) so a light
dusting with 220 I think then step it down (finer, grit wise ) on the next
two coats.
Does it seem like I'm on the right track ?
Old 12-05-2010, 07:19 PM   #5
DIY staff
Rewards Points: 7,174
I find that I get the best results with trim by laying on a fairly heavy coat-then quickly even out the finish with the brush--it seems to level itself out that way.
Old 12-06-2010, 09:38 PM   #6
Rewards Points: 410
OK thanks for the tips guys things are looking tremendously better.
white trim vs. wood stained nwalford Interior Decorating 17 02-28-2011 03:54 AM
trim around wood floor Diann Flooring 3 09-25-2010 08:14 PM
Deadbolt and Wood Trim question troymcclure Building & Construction 8 05-18-2009 07:12 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
Exterior trim paint is peeling, wood is rotting! firsthomenewb Painting 10 05-15-2008 06:04 PM
