Wood Trim On Concrete Slab..... - Painting - DIY Chatroom Home Improvement Forum
Old 07-08-2010, 08:00 AM   #1
Wood trim on concrete slab.....
Hello,
I have poplar baseboard trim that will be primed and painted and will be in contact with a concrete slab. While my walkout basement does not have a water problem, there is inherently moisture in the slab which is in contact with the ground. I'm concerned that the wood trim will absorb moisture from the slab and possibly rot. Is this a valid concern and what measures might I take with respect to my coatings for primer and finish coat?
Thank you,
Steve
wolftrader is offline   Reply With Quote
Old 07-08-2010, 10:03 AM   #2
Concrete and Wood do not mix, with exception of pressure treated lumber. Keep your trim up from the concrete 1/8 or 1/4 inch.............
Prime and paint to be used should be from a Paint Company/Store as apposed to the big boxed stores......IMO mind you!
mark942 is offline   Reply With Quote
Old 07-08-2010, 10:08 AM   #3
Primer
Ok, I'll raise it, good suggestion, how about my primer, is latex ok or should I go to oil?
The concrete floor is acid etched which is why the trim won't be on wood or carpet.
Old 07-08-2010, 03:53 PM   #4
KM has great oil and they also have some great latex as well. Oil is IMO is the best way to go Primer/Paint, Enamel. But I tend to be old school. If you have the time,ventilation and the ability with oil, I would go Oil. If your looking to get your trim done in a faster pace then I would go latex. Oil Primer and latex top coat might be the ticket as well. Like I said KM has some great product lines. You just have to choose is all......................
Good Luck....................
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Lay plastic between ground and concrete slab? Flt_Simulation Flooring 8 04-22-2012 05:56 AM
How to cut a hole in a concrete floor slab tomseeley General DIY Discussions 7 06-10-2009 02:32 PM
Exterior wood door frame on concrete floor RosenKen Building & Construction 3 06-05-2009 02:23 PM
Tile with a wood trim? trick29392 Flooring 3 06-26-2008 07:19 AM
