Old 09-16-2012, 06:10 PM   #1
Wood staining questions
first staining project.
I built a crib out of white oak.
I'm using Minwax oil stain.
Several people told me that I didn't need the pre-stain because the wood is white oak. So I didn't use it.
I sanded thoroughly (so i thought) with 220 all over, and applied the first layer of stain. When i wiped the stain off, there were places on the wood where the stain didn't take. In some cases, I'm sure it was glue residue. I sanded a lot, but the spots are along the glued seams, so that seems obvious. A few others are in the field of the wood (mainly the plywood parts, not the hardwood parts). And there are a few tiny spots throughout where no stain go into the areas with deeper grain.
I'm about to apply a second coat, and I'm not sure how to proceed.
The stain instructions say not to sand between coats.
Should I go over the bad spots with 220 again before the second coat? Should I try to "spot stain" the bad areas before putting on a second coat?
Should I sand the entire thing with a finer grit to keep it uniform?
or quite simply, what should I do to get a more uniform stain?
(The stain is not "splotchy", it's just these spots that didn't take stain.)
wengang1 is offline   Reply With Quote
Old 09-16-2012, 09:29 PM   #2
It sounds like you used only 220. I'd recommend sanding it good with a 100 grit, then 150, then 220. You always want to work into your fine sanding.
FTF-Tom is offline   Reply With Quote
Old 09-17-2012, 10:49 AM   #3
You're right. That's what I did.
But I've already stained the whole project with one coat.
So the question is, should I sand the entire project again or just the trouble spots, and should I go down to a coarser grit and then 220 again?
There's no way I can sand back down below the stain at this point. I just don't know what the effects of sanding the stain with 220 will be.
Laminate wood flooring on slab newb questions shark974 Flooring 3 11-11-2011 06:57 AM
staining over finished wood Isabelbr Carpentry 3 01-21-2011 06:55 PM
Staining vs just sealing preserved wood deck? Hossenfeffer Painting 1 05-28-2010 06:20 PM
staining a wood walkway brendam Painting 4 04-01-2010 01:45 PM
Staining concrete flooring - questions on cleanup and relief cuts vseven Flooring 3 12-15-2009 09:07 AM
