Wood Primer For Bare 2x Material In Garage? - Painting - DIY Chatroom Home Improvement Forum
Old 05-21-2014, 10:12 PM   #1
Dave88LX's Avatar
Rewards Points: 502
Wood primer for bare 2x material in garage?
I'm painting my garage here shortly after I finish the mediocre mudding and taping job the drywallers did.
There is a bit of exposed 2x framing on the garage door wall. Can I just prime this with the same S-W Drywall Primer, or is there a specific primer that I should use? As you can see, it's not a whole lot to cover. Maybe $15 or so for a quart.
Dave88LX is offline   Reply With Quote
Old 05-21-2014, 10:29 PM   #2
Jmayspaint's Avatar
The SW drywall primer is rated for use on interior wood also. You'll be fine using it in around the garage doors.
Jmayspaint is offline   Reply With Quote
Old 05-22-2014, 09:58 AM   #3
Dave88LX's Avatar
Rewards Points: 502
Awesome, thanks. I didn't see anything on it about wood so I wasn't sure.
Old 05-22-2014, 10:16 AM   #4
Jmayspaint's Avatar
Probably doesn't say it on the can, but the data sheet lists wood as an approved substrate. Might not be the best choice for priming all the trim in your house, but it will work fine for that.
http://www.sherwin-williams.com/docu.../035777135921/
wood floor over garage floor bluebird5 Building & Construction 2 09-29-2013 09:56 AM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 10:32 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
